Everytime i strat up autocad the autocad message come up and say.. Customization file load failed. File not found: C;Users........ When i press ok it still loads but i dont have any tool bars and there is not way to make them come up. What can i do about this because i dont want to have to download 2012 of the student version.
Solved by asburyj. Go to Solution.
Hi Darrell and welcome to the forum,
It sounds like you may have a damaged customization file. Can you try resetting your settings to default? 2011 didn't have the tool to do that automatically so here's a link on how to manually reset the settings.
Thank you very much jeff. It works.... So now i am back to using autocad 2011.. Thank alot buddy...
