Installation & Licensing
New Member
Terryb
Message 1 of 2 (71 Views)
Autocad 2000i and Netscape
71 Views, 1 Replies
11-13-2000 01:00 PM
Hi... Got an apparent problem and a question. Apparently Autocad Map 2000i
requires the installation and use of Internet Explorer in order to run the program,
and will not work (at least in some ways) with Netscape as the system browser.
The question (actually two questions). (1) Is there a work around to use Netscape
with Autocad Map 2000i in place of Internet Explorer? (We would prefer to avoid
Internet Explorer for security reasons). This change is forcing us to choose between
maintaining a reasonably secure environment and using Autocad.
(2) Apparently the help system is also broken if IE is not installed. Help is such a
vital part of a complex application that it should not be dependent on the use
of a particular browser.
Thanks for any workarounds or guidance that anyone can provide.
*Nehls, Kevin
Message 2 of 2 (71 Views)
Re: Autocad 2000i and Netscape
11-13-2000 03:06 PM in reply to: Terryb
"Terryb" wrote in message
news:ef4ee31.-1@WebX.SaUCah8kaAW...
program,
browser.
Netscape
No.
Help is such a
use
2000i's help files are CHM (compiled help files) that can only run in IE, no
other browser can run these files period, end of story.
The only work around is to install IE 5 and remove the icons from the start
menu and remove it from the desktop. To do the former you have to delete
them from the "start menu\programs" directory. The latter can be
accomplished by right-clicking on the icon, then on properties, then on the
advanced tab and finally un-checking the proper option in the advanced tab.
Now you've just made it a lot harder for the user to launch IE and IE will
still be on the machine for 2000i's help files.
BTW, if you upgrade to Win98SE (maybe Win98), WinME, or Win2K, you cannot
get around not having IE 5.x on the system.
HTH
Kevin Nehls
remove -ns- for direct reply
You are not logged in.
Announcements
Need installation help?
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
