Installation & Licensing
*Weiss, Lenny
Message 1 of 2 (90 Views)
Autocad 14 on network
90 Views, 1 Replies
12-10-1999 09:45 AM
<<< Message <82r84n$1du14@adesknews2.autodesk.com> was originally posted to 'autodesk.autocad.r14general' on Fri, 10 Dec 1999 10:01:31 -0600.>>>
For some reason when we brought up autocad this morning it gave us a message
FATAL ERROR: Secuity system(hardware lock or network license)
is not functioning or is improperly installed.
We checked the server and the license manger is running. The only
thing I can think of is the server had a ethernet card and a token ring card
we took
out the token ring card. Could this be it and if it is what do we do.
Lenny Weiss
Dakota County
*Milana, Jerry
Message 2 of 2 (90 Views)
Re: Autocad 14 on network
12-13-1999 04:32 PM in reply to: *Weiss, Lenny
Lenny,
Any change to the network setup of the system used as the AdLM Server may invalidate your authorization. To correct this, generate a new server
code using AdLM Admin and obtain a new auth code from AutoCAD based on the new Server Code.
By the way, we do not recommend running AdLM an systems that have multiple network adapters as this can cause reliability problems.
Jerry Milana,
Autodesk Product Support
> we took
> Lenny Weiss
> Dakota County
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
