Installation & Licensing
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
AutoDesk products using Windows Server 2008 RemoteApp
- Highlight
- Email to a Friend
- Report Inappropriate Content
I am looking at virtualizing AutoCAD 2013 (and a few other AutoDesk products) using application virtualization. Citrix XenApp is much more expensive compared to RemoteApp provided by Windows Server. But, I hear that only XenApp is supported virtualization platform. Is that true? Would I violate any Autodesk EULA by running the product using RemoteApp?
Re: AutoDesk products using Windows Server 2008 RemoteApp
- Highlight
- Email to a Friend
Unless you used the Citrix solution, you would be violating the EULA by running it on the server this way. You certainly do not want an audit. Other companies threaten, Autodesk follows through.
My Expert Contributions to the Discussion Groups: FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!Re: AutoDesk products using Windows Server 2008 RemoteApp
- Highlight
- Email to a Friend
If you have a citrix license pool and install the Autodesk app with a deployment that uses the citrix license on your remoteapp server than I would think you would be ok? Someone from Autodesk please correct me if I'm wrong.
Thanks!
