Installation & Licensing
AutoDesk Upgrade Network Licensing Question
4 REPLIES 4
engineering
285 Views, 4 Replies
Hello all!  I've searched through the forums and haven't seen an answer to my exact situation.  Hopefully you can help me out.
We recently upgraded 2 of our AutoDesk licenses from 2013 to 2014.  The serial numbers remained the same.
We already have the network license manager in place and it is currently working for 2013, and is on the latest version (11.11 I believe).
My question is this: since the serial numbers stayed the same will I need to obtain a new license file and put that in place for 2014, or will the license manager just reference the serial number and know that the license is valid for both 2013 and 2014?
Thanks much for your help.
4 REPLIES 4
DarrenP
in reply to: engineering
thats not possible serial numbers change with every version
if you upgraded from 2013 to 2014 the serial number is not the same it changed when you upgraded to 2014
the license file would have to be regenerated for the 2014 licenses
DarrenP
engineering
in reply to: DarrenP
Oh- you're right.
Here's the odd thing though- the new serial numbers are in our license manager but I have not yet upgraded the software for any of the users, so they are still using 2013 and the license manager is allowing them to run.
Is that odd or is that normal behavior?
DarrenP
thats normal
if your on subscription you can run 2014, 2013, 2012, 2011
to verify run your license file through here
www.licenseparser.com
you should see multiple versions in your license file
DarrenP
DarrenP
you should see something like this
Subscription Package: AutoCAD 64300ACD_F 111-11111111   permanent
  AutoCAD 2014 86063ACD_2014_0F
  AutoCAD 2013 85871ACD_2013_0F
  AutoCAD 2012 85730ACD_2012_0F
  AutoCAD 2011
85536ACD_2011_0F
DarrenP
Administrator Productivity
