I'm on my third attempt to download Revit. Each time the download proceeds normally until about 1.68G of a 2.78G download. At this point there is no more activity, even after an hour. All the pre-installation checks have been done. What is the problem?
Hi pdsmith:
Prior to download, please check your system for and disable any of the following:
# Firewall - These are designed to stop downloads from non-approved sites.
# Anti-Virus Programs - These will try to stop or scan a download. It may cause the download to be corrupt or damaged.
# Download Monitors - Programs such as GoZilla! and NetZip are not compatible with our server and will sometimes block or stop downloads.
# Screen Savers - In some instances, screen savers can interfere with the download process. If you have a screen saver that is starting while you are downloading, please disable it temporarily until your download is complete.
You can download the trial version from this link and activate it using your serial number and product key.
I hope this helps!
Best Regards,
