Hi.
I am installing AutoDesk PDS 2015 to windows 7 x64 machines silently using the following command.
\\share\AutoDesk\PDS\2015\script\x64\Img\Setup.exe /W /q /I Img\AutoDesk PDSU 2015.ini /language en-us
All programs install ok however after install the following popup message is generated.
has anyone seen this ? It happens before we even launch any autodesk app so i assume its a background service.
Cheers.
I think it is waiting on you to answer. Why not just create a silent install deployment? That will accomplish what you are looking for.
did you read my post at all?
i said:
Trying to install: \\share\AutoDesk\PDS\2015\script\x64\Img\Setup.exe /W /q /I Img\AutoDesk PDSU 2015.ini /language en-us
thats the silent switch supplied in autodesks help file.
As i also stated, the install completes fine.,
Any resolve to this? I have encountered the same error while trying to deploy using PDQDeploy and the same arguments.
It does install, but with the MSIEXEC still in process as the Deploy User and ACAD won't start until it's manually ended or the PC is rebooted.
After closing out the msiexec what is left in process under the deploy user is AdAppMgr.exe
installler always ended ok, ive added the installer to seek reboot status pending from a powershell before attempting to run,
#Based on <http://gallery.technet.microsoft.com/scriptcenter/Get-PendingReboot-Query-bdb79542>
function Test-RebootRequired
$result = @{
CBSRebootPending =$false
WindowsUpdateRebootRequired = $false
FileRenamePending = $false
SCCMRebootPending = $false
#Check CBS Registry
$key = Get-ChildItem "HKLM:Software\Microsoft\Windows\CurrentVersion\Component Based Servicing\RebootPending" -ErrorAction Ignore
if ($key -ne $null)
$result.CBSRebootPending = $true
#Check Windows Update
$key = Get-Item "HKLM:SOFTWARE\Microsoft\Windows\CurrentVersion\WindowsUpdate\Auto Update\RebootRequired" -ErrorAction Ignore
if($key -ne $null)
$result.WindowsUpdateRebootRequired = $true
#Check PendingFileRenameOperations
$prop = Get-ItemProperty "HKLM:SYSTEM\CurrentControlSet\Control\Session Manager" -Name PendingFileRenameOperations -ErrorAction Ignore
if($prop -ne $null)
#PendingFileRenameOperations is not *must* to reboot?
#$result.FileRenamePending = $true
#Check SCCM Client <http://gallery.technet.microsoft.com/scriptcenter/Get-PendingReboot-Query-bdb79542/view/Discussions#...
try
$util = [wmiclass]"\\.\root\ccm\clientsdk:CCM_ClientUtilities"
$status = $util.DetermineIfRebootPending()
if(($status -ne $null) -and $status.RebootPending){
$result.SCCMRebootPending = $true
catch{}
#Return Reboot required
return $result.ContainsValue($true)
If (test-rebootrequired)
## - Custom Exit Code:
[Environment]::Exit ("9999")
}else{
## - Execute batch File:
start-process INSTALLAUTODESK.CMD
