I've been tring to install Autodesk inventor 2013 for a new lab where I work. It will create the deployment correctly, and when I try to run the deployment it starts off correctly but then it fizzles out and rolls back any changes. Now I've tried this from the deployment, I've tried installing directly from the flash drive that autodesk sent me and I get the same thing. Now 1 computer I could understand, but 25 brand new intel i5 machines with a fresh install of windows 7. Here is the log message that I get
2012/9/24:08:00:27 SETECH GTT-SE3204-06 === Setup started on GTT-SE3204-06 by SETECH ===
2012/9/24:08:00:27 SETECH GTT-SE3204-06 Launch
2012/9/24:08:00:36 SETECH GTT-SE3204-06 === Setup ended ===
2012/9/24:08:00:33 SETECH GTT-SE3204-06 === Setup started on GTT-SE3204-06 by SETECH ===
2012/9/24:08:00:33 SETECH GTT-SE3204-06 Launch
2012/9/24:08:00:36 SETECH GTT-SE3204-06 Inventorui== Parameter: Prereq_13 SetupMode:1 InstallState:2 InstallAction:0 Message:
2012/9/24:08:00:36 SETECH GTT-SE3204-06 Inventorui== Parameter: Prereq_14 SetupMode:1 InstallState:2 InstallAction:7 Message:
2012/9/24:08:00:36 SETECH GTT-SE3204-06 Inventorui== Parameter: Prereq_3 SetupMode:1 InstallState:1 InstallAction:0 Message:
2012/9/24:08:00:36 SETECH GTT-SE3204-06 Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): \\SE1308-JTECH\Share\Autodesk Inventor\Inventor\AdminImage\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe /q /norestart
2012/9/24:08:00:38 SETECH GTT-SE3204-06 Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=1603
2012/9/24:08:00:40 SETECH GTT-SE3204-06 === Setup ended ===
Note: I've went through and removed all versions of visual C++ from the machine. I've tried to let this install through the deployment as well as going back and installing the versions of C++ by hand from the 3rdparty folder, all with the same result. Not sure what to do from here.
Hello:
Please try the following:
Create a local test user account on the computer and give it administrator rights, log in to computer under this test account. Turn UAC off and Antivirus off and remove the Microsoft Visual C++ 2010 x86/x64 from the computer then try to install from the flash drive again. Let us know the results.
Byron Morales
Product Support | Up and Ready Blog | If my reply was helpful, please Kudo or Accept as Solution.
