I am trying to reinstall AutoDesk 2011 LT
Unfortunately it errors out each time and will not initialize. It even references a drive Z which does not exist on the computer
Initially we had the 2013 trial installed and that would not uninstall (even with the uninstall tools from the AutoDesk website).
Although AutoDesk has been quite helpful I really think I need to remove every vestige of Autodesk, both versions and then try a clean install.
Is there any global tool like that?
Any help will be greatly appreciated!
Hello Patrick,
Welcome to the Discussion Forums!
We do actually have a set of directions on how to remove all Autodesk products from a Windows operating system which will assist you with the clean uninstall.
I hope you find this helpful! But be sure to let us know if you have any other questions!
Thanks so much,
