Installation & Licensing
AutoCad will not start until Licence Manager is restarted
2 REPLIES 2
DKP123
323 Views, 2 Replies
When we reboot our AutoCad2000 station the License Manager starts and looks to be working fine. If you try to open AutoCad though, it will not run because it can't find a license. Once the License Manager is shutdown and restarted manually, everything works fine. Any ideas??
Below is from C:\ADLM\LOG\ADLM.log
***********Started ADLM manually (note mac address!)****************************************
01-Nov-07 12:59:15: Autodesk License Manager - Copyright 1997 Elan Computer Group, Inc.
01-Nov-07 12:59:15: ADLM 5.0.1c started on drop201 (00c095e60328).
01-Nov-07 12:59:15: Vendor ID = 1a2ccac.
01-Nov-07 12:59:15: Default Hostcode = 1536 (03000) = ETHER+HISECURE.
01-Nov-07 12:59:15: PID = 305.
01-Nov-07 12:59:15: Port = 1422.
01-Nov-07 12:59:15: Log file = C:\ADLM\LOG\ADLM.LOG.
01-Nov-07 12:59:15: Key path = C:\ADLM\KEY.
01-Nov-07 12:59:15: Keyaccept = 310.
01-Nov-07 12:59:15: Resource file = .
01-Nov-07 12:59:15: Message level = 3.
01-Nov-07 12:59:15: Max log file size = 65536 bytes.
01-Nov-07 12:59:15: Initialization period = 180 seconds.
01-Nov-07 12:59:15: Peer registered: "drop201" 00c095e60328 c0a802c9 192.168.2.201 192.168.2.201.
01-Nov-07 12:59:15: Loaded key C:\ADLM\KEY\150.lic 1 tokens [MINIKEY].
***********ADLM started automatically after reboot (note failures and mac address!)****************************************
01-Nov-07 13:07:01: Warning: Unable to obtain HostID #1 (ETHER+HISECURE) on "drop201": System error.
01-Nov-07 13:07:01: Host ID failures: pausing 60 seconds and trying again.
01-Nov-07 13:08:01: Warning: Unable to obtain HostID #1 (ETHER+HISECURE) on "drop201": System error.
01-Nov-07 13:08:01: Autodesk License Manager - Copyright 1997 Elan Computer Group, Inc.
01-Nov-07 13:08:01: ADLM 5.0.1c started on drop201 (c0a802c9).
01-Nov-07 13:08:01: Vendor ID = 1a2ccac.
01-Nov-07 13:08:01: Default Hostcode = 1536 (03000) = ETHER+HISECURE.
01-Nov-07 13:08:01: PID = 71.
01-Nov-07 13:08:01: Port = 1422.
01-Nov-07 13:08:01: Log file = C:\ADLM\LOG\ADLM.LOG.
01-Nov-07 13:08:01: Key path = C:\ADLM\KEY.
01-Nov-07 13:08:01: Keyaccept = 310.
01-Nov-07 13:08:01: Resource file = .
01-Nov-07 13:08:01: Message level = 3.
01-Nov-07 13:08:01: Max log file size = 65536 bytes.
01-Nov-07 13:08:01: Initialization period = 180 seconds.
01-Nov-07 13:08:01: Peer registered: "drop201" c0a802c9 c0a802c9 192.168.2.201 192.168.2.201.
01-Nov-07 13:08:01: Authorization failure; key C:\ADLM\KEY\150.lic only valid for: drop201.
2 REPLIES 2
in reply to: DKP123
the 1st thing to come to mind is that the 3 minute delaytime for the
ADLM to initialize is too short. The server may be initializing
networkresources and the networkadapter may not be in the state ADLM
wants in 3 minutes. Try increasing the delaytime to 5 minutes. (Control
panel-> ADLM -> Settings.) This may help
Cheers,
Petri ahava
CAD-Q Finland
> * **********Started ADLM manually (note mac
> address!)**************************************** 01-Nov-07 12:59:15:
> * **********ADLM started automatically after reboot (note failures and mac
> valid for: drop201.
in reply to: DKP123
Douglas -
Is there more than 1 network card (and modems, X25 pads, etc count as network cards) in the adlm server? The elan adlm doesn't
support more than 1 network card. It might work sometimes, but these are the kinds of problems that the Elan Adlm has on machines
with multiple network cards.
jason martin
frankfurt-short-bruza
Member of the Autodesk Discussion Forum Moderator Program
"DKP123" wrote in message news:f0b55e7.-1@WebX.maYIadrTaRb...
Any ideas??
(snip adlm log)
Administrator Productivity
