the 1st thing to come to mind is that the 3 minute delaytime for the
ADLM to initialize is too short. The server may be initializing
networkresources and the networkadapter may not be in the state ADLM
wants in 3 minutes. Try increasing the delaytime to 5 minutes. (Control
panel-> ADLM -> Settings.) This may help
Cheers,
Petri ahava
CAD-Q Finland
DKP123 wrote:
> When we reboot our AutoCad2000 station the License Manager starts and
> looks to be working fine. If you try to open AutoCad though, it will not
> run because it can't find a license. Once the License Manager is
> shutdown and restarted manually, everything works fine. Any ideas??
> Below is from C:\ADLM\LOG\ADLM.log
> * **********Started ADLM manually (note mac
> address!)**************************************** 01-Nov-07 12:59:15:
> Autodesk License Manager - Copyright 1997 Elan Computer Group, Inc.
> 01-Nov-07 12:59:15: ADLM 5.0.1c started on drop201 (00c095e60328).
> 01-Nov-07 12:59:15: Vendor ID = 1a2ccac.
> 01-Nov-07 12:59:15: Default Hostcode = 1536 (03000) = ETHER+HISECURE.
> 01-Nov-07 12:59:15: PID = 305.
> 01-Nov-07 12:59:15: Port = 1422.
> 01-Nov-07 12:59:15: Log file = C:\ADLM\LOG\ADLM.LOG.
> 01-Nov-07 12:59:15: Key path = C:\ADLM\KEY.
> 01-Nov-07 12:59:15: Keyaccept = 310.
> 01-Nov-07 12:59:15: Resource file = .
> 01-Nov-07 12:59:15: Message level = 3.
> 01-Nov-07 12:59:15: Max log file size = 65536 bytes.
> 01-Nov-07 12:59:15: Initialization period = 180 seconds.
> 01-Nov-07 12:59:15: Peer registered: "drop201" 00c095e60328 c0a802c9
> 192.168.2.201 192.168.2.201.
> 01-Nov-07 12:59:15: Loaded key C:\ADLM\KEY\150.lic 1 tokens [MINIKEY].
> * **********ADLM started automatically after reboot (note failures and mac
> 01-Nov-07 13:07:01: Warning: Unable to obtain HostID #1 (ETHER+HISECURE)
> on "drop201": System error.
> 01-Nov-07 13:07:01: Host ID failures: pausing 60 seconds and trying again.
> 01-Nov-07 13:08:01: Warning: Unable to obtain HostID #1 (ETHER+HISECURE)
> 01-Nov-07 13:08:01: Autodesk License Manager - Copyright 1997 Elan
> 01-Nov-07 13:08:01: ADLM 5.0.1c started on drop201 (c0a802c9).
> 01-Nov-07 13:08:01: Vendor ID = 1a2ccac.
> 01-Nov-07 13:08:01: Default Hostcode = 1536 (03000) = ETHER+HISECURE.
> 01-Nov-07 13:08:01: PID = 71.
> 01-Nov-07 13:08:01: Port = 1422.
> 01-Nov-07 13:08:01: Log file = C:\ADLM\LOG\ADLM.LOG.
> 01-Nov-07 13:08:01: Key path = C:\ADLM\KEY.
> 01-Nov-07 13:08:01: Keyaccept = 310.
> 01-Nov-07 13:08:01: Resource file = .
> 01-Nov-07 13:08:01: Message level = 3.
> 01-Nov-07 13:08:01: Max log file size = 65536 bytes.
> 01-Nov-07 13:08:01: Initialization period = 180 seconds.
> 01-Nov-07 13:08:01: Peer registered: "drop201" c0a802c9 c0a802c9
> 01-Nov-07 13:08:01: Authorization failure; key C:\ADLM\KEY\150.lic only
> valid for: drop201.
