Installation & Licensing
AutoCad Mechanical 2011 install failed
1 REPLY 1
313 Views, 1 Reply
Hi there
I am doing a complete re-install of Inventor 2011. Inventor has installed ok but AutoCad Mechanical 2011 fails. Below is the log file:
2011/11/10:09:45:34 Martyn Tanner MARTYNPC === Setup started on MARTYNPC by Martyn Tanner ===
2011/11/10:09:48:10 Martyn Tanner MARTYNPC === Setup ended ===
2011/11/10:09:47:52 Martyn Tanner MARTYNPC === Setup started on MARTYNPC by Martyn Tanner ===
2011/11/10:10:15:58 Martyn Tanner MARTYNPC Install Microsoft Visual C++ 2005 Redistributable Succeeded
2011/11/10:10:16:06 Martyn Tanner MARTYNPC Install DirectX 9.0 Runtime Failed Failure is ignored, Result=-9
2011/11/10:10:18:56 Martyn Tanner MARTYNPC Install DWG TrueView 2011 Succeeded
2011/11/10:10:20:30 Martyn Tanner MARTYNPC Install Autodesk Material Library 2011 Succeeded
2011/11/10:10:21:32 Martyn Tanner MARTYNPC Install Autodesk Material Library 2011 Base Image library Succeeded
2011/11/10:10:30:41 Martyn Tanner MARTYNPC Install Autodesk Inventor 2011 Succeeded
2011/11/10:10:39:20 Martyn Tanner MARTYNPC Install Autodesk Inventor 2011 English Language Pack Succeeded
2011/11/10:10:49:14 Martyn Tanner MARTYNPC Install Autodesk Inventor Suite 2011 Service Pack 1 Succeeded
2011/11/10:10:49:34 Martyn Tanner MARTYNPC Install FARO LS 1.1.406.58 Failed Installation aborted, Result=1603
2011/11/10:10:50:55 Martyn Tanner MARTYNPC === Setup ended ===
2011/11/10:11:01:43 Martyn Tanner MARTYNPC === Setup started on MARTYNPC by Martyn Tanner ===
2011/11/10:11:02:46 Martyn Tanner MARTYNPC === Setup ended ===
2011/11/10:11:02:29 Martyn Tanner MARTYNPC === Setup started on MARTYNPC by Martyn Tanner ===
2011/11/10:11:17:42 Martyn Tanner MARTYNPC Install DirectX 9.0 Runtime Succeeded
2011/11/10:11:18:12 Martyn Tanner MARTYNPC Install FARO LS 1.1.406.58 Failed Installation aborted, Result=1603
Any assistance would be gratefully received.
1 REPLY 1
hashim.mundol
Please try
http://forums.autodesk.com/t5/Installation-Licensing/Civil-3D-2011-fails-to-install/td-p/2823652
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
For more tips & tricks: http://upandready.typepad.com
Hashim Mundol
Autodesk Product Support
Autodesk, Inc.
Administrator Productivity
