• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    Product Support
    Re: AutoCad LT 2013 GPO install issue gpo.mst
    09-27-2012 01:29 AM in reply to: martin.franc
    hi Martin
    Thanks for testing, it. I have re-produced the issue in the lab. and found a work around.
    Please use the attached mst (gpo_for_sp1.mst, attached as zip) file instead  of gpo.mst against acadlt.msi
    For other msi files (AcadLTLP.msi,AcadLTPS.msi) pelase use the original gpo.mst file.
    Please let me know if this helps in deploying AutoCAD LT 2013 Sp1.1
    If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
    For more tips & tricks: http://upandready.typepad.com
    Hashim Mundol
    Autodesk Product Support
    Autodesk, Inc.
    Please use plain text.
    09-27-2012 01:58 AM in reply to: hashim.mundol
    Thanks, maybe I'll try it later today.
    It is also applicable to the x86 version of ACLT2013 (SP1.1)? It has the same problem.
    Product Support
    09-27-2012 03:01 AM in reply to: martin.franc
    Yes it should work on 32 and 64 bit.
    Hashim Mundol
    Autodesk, Inc.
    09-27-2012 03:54 AM in reply to: hashim.mundol
    Meanwhile... I found same issue in AutoCad 2013 and SP1.1...
    09-27-2012 05:33 AM in reply to: hashim.mundol
    I tested it on virtual W7Px64 and it appears that it work (gpo_for_sp1.mst for LT2013). Good job :smileyhappy:. Thank You.
    Product Support
    09-27-2012 05:35 AM in reply to: hashim.mundol
    thanks for testing,
    same file should work for AutoCAD 2013  SP1.1 too, I haven't tested yet..
    Hashim Mundol
    Autodesk, Inc.
    09-27-2012 05:38 AM in reply to: hashim.mundol
    Really? Give me 30 minutes.... :smileyhappy:
    09-27-2012 06:22 AM in reply to: martin.franc
    Thanks, works fine with ac&aclt2013. :smileyhappy:
    Product Support
    09-27-2012 06:51 AM in reply to: martin.franc
    Thanks for confirming.
    Hashim Mundol
    Autodesk, Inc.
    Valued Contributor
    11-07-2012 12:51 PM in reply to: hashim.mundol
    Good Lord, Thank You Hashim!!!
    This file works for AutoCAD MEP 2013 w/SP1 embedded as well.
    FTR Autodesk Technical Support (1-2 months ago) told me this was because my adminimage share path was excessively-long (even though it wasn't for the prior 5 years of builds).
