Installation & Licensing
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
AutoCad LT 2013 GPO install issue gpo.mst
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I made a new administrative package, together with the merger with SP1.1. I'm going to put to the test policy (acadlt.msi) and voila. Add the first change script can (ACAD-ACLT2013ENSP1.1x64.mst), the second standard can not (gpo.mst) - AD resist "An error occured Accessing the software installlation data in the active directory". Standard message So when I try to cram wrong somewhere mst, missing information about the version of the application. Was already the same problem with this Civil 2013.
Re: AutoCad LT 2013 GPO install issue gpo.mst
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
We tested this on our side,We are not able to re-produce this on 64bit Image of AutoCAD LT 2013.
Can you try to add this using Active Directory client running on another OS.(2003/Xp etc..)
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
For more tips & tricks: http://upandready.typepad.com
Hashim Mundol
Autodesk Product Support
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I try do this directly from AD console on W2K8R2. Domain and forest functional level is Windows Server 2008 R2. I think I'll do one more attempt. I download the English installation package and create LT2013 x64 description step by step.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Steps 1 to 12 :create a standard network image (LT2013 x64 EN package downloaded today from Autodesk) + merge with SP 1.1
1) Run setup as administrator
2) Create deployment
3) Conf. name and network path, standard installation settings
4) EULA
5) Serial number
6) Settings part1 (change - deselect Display Welcome screen... in User Preferences)
7) Settings part2 (change - select location of SP and set option "Merge...")
8) Settings part3 (change - deselect "Enable live updates")
9) Settings part4 (change - select "Allow users to recieve...")
10) Making of network image with SP1.1
11) Network image completed
12) Network location ready
Step 13-25 Our AD
prerequisites:
A Global security group named G SWITestAPP
A Group policy object named SWI TestAPP
13) A tree of group policy in GPMC where is "GPO SWI TestAPP" (a clear gpo without settings)
14) remove "Authenticated Users" group from delegation/filtering GPO SWI TestAPP
15) add group "G SWITestAPP" to security filtering of GPO "SWI TestAPP" with "Apply Group policy" Permitions
16) status of GPO changed to "User configuration settings disabled" because instalation used only part of machine policy
17) Start editing GPO "SWI TestAPP"
18) Configure new package
19) Select msi file from network image
20) Selected method: Advanced
21) Configuration of... Name
22) Configuration of... Deployment and Advanced options
23) Configuration of... Modifications - set 1st mst file (aclt-nameofimage.mst)
24) Configuration of... Modifications - set 2nd mst file (gpo.mst)
25) and click OK = Error
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Steps 13-17
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Steps ...to 25
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
What is the error in the event viewer ?
Hashim Mundol
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
App log chronologically :
og Name: Application
Source: Software Installation
Date: 26.9.2012 10:39:45
Event ID: 119
Task Category: None
Level: Warning
Keywords: Classic
User: N/A
Computer: xxx
Description:
Software Installation encountered an unexpected error while reading from the MSI file \\sph00\ADIB\Test\ACLT2013ENx64SP1.1\AdminImage\x6
Log Name: Application
Source: MsiInstaller
Event ID: 1040
Task Category: None
Level: Information
Keywords: Classic
User: EGEM\damf_01
Computer: xxx
Description:
Beginning a Windows Installer transaction: \\sph00\ADIB\Test\ACLT2013ENx64SP1.1\AdminImage\x6
Date: 26.9.2012 10:39:47
Event ID: 1042
Task Category: None
Level: Information
Keywords: Classic
User: SYSTEM
Computer: XXX
Description:
Ending a Windows Installer transaction: \\sph00\ADIB\Test\ACLT2013ENx64SP1.1\AdminImage\x6
Source: Microsoft-Windows-RestartManager
Date: 26.9.2012 10:39:46
Event ID: 10000
Task Category: None
Level: Information
Keywords:
User: EGEM\damf_01
Computer: XXX
Description:
Starting session 0 - 2012-09-26T08:39:46.432468600Z.
Event ID: 10001
Task Category: None
Level: Information
Keywords:
User: EGEM\damf_01
Computer: XXX
Description:
Ending session 0 started 2012-09-26T08:39:46.432468600Z.
Date: 26.9.2012 10:42:26
Event ID: 1040
Task Category: None
Level: Information
Keywords: Classic
User: EGEM\damf_01
Computer: XXX
Description:
Event ID: 1042
Task Category: None
Level: Information
Keywords: Classic
User: SYSTEM
Computer: XXX
Description:
Log Name: Application Source: Software Installation Date: 26.9.2012 10:42:26 Event ID: 110 Task Category: None Level: Error Keywords: Classic User: N/A Computer: xxx Description: Software Installation was unable to generate the script for \\sph00\ADIB\Test\ACLT2013ENx64SP1.1\AdminImage\x6
Log Name: Application Source: Software Installation Date: 26.9.2012 10:42:26 Event ID: 101 Task Category: None Level: Error Keywords: Classic User: N/A Computer: xxx Description: Software Installation encountered the following error: Error applying transforms. Verify that the specified transform paths are valid.
its all
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
could you please try without SP1 ?
Hashim Mundol
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
You think LT2013 without SP1.1...? Yes i have, yes its working. I have 50 clients in domain with LT2013EN (+CZ lang pack) distributed via AD/GPO. Its about 80 installations (clients have laptops and workstations). And versions LT2012/LT2011 with SP2 too.
