Installation & Licensing
New Member
Message 1 of 5 (430 Views)
AutoCad Education Master Suite 2013 fails install Architectu​re 2013 Error 1603
430 Views, 4 Replies
01-02-2013 11:27 AM
I am recieving the Error 1603 when installing Architecture 2013.  I have done the following things to try and solve the issue.
First I uninstalled and reinstalled all of the VCREDIST (Microsoft Visual C++) packages.
Next I tried and uninstalled the AutoCad 2013 SP 1.1.
UAC is turn off.
AV is turn off
I am attaching the error log file
*Expert Elite*
TravisNave
Message 2 of 5 (423 Views)
Re: AutoCad Education Master Suite 2013 fails install Architectu​re 2013 Error 1
01-02-2013 02:44 PM in reply to: candymann999
Architecture will not install if AutoCAD 2013 is already installed from another suite.  They both try to install into the AutoCAD 2013 folder.  If that folder exists, delete it and it will install.  You do not need vanilla AutoCAD if you are also installing a vertical product like Architecture or Mechanical because it also includes Vanilla.
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
New Member
Message 3 of 5 (407 Views)
01-03-2013 12:34 PM in reply to: candymann999
To solve my issue I have to start from scratch and reinstall everything minus all service packs for all products.
New Member
Message 4 of 5 (114 Views)
07-18-2013 06:34 PM in reply to: candymann999
I spent a good part of today trying to install autodesk inventor 2013 and I too am getting the same error code.  so to be clear I have to uninstall my previous inventor installation to make this work?  Is there any other way?  to be sure I am uploading the install log.  Thank you in advance.
*Expert Elite*
TravisNave
Message 5 of 5 (103 Views)
07-19-2013 10:45 AM in reply to: bristang5
No, you do not have to uninstall your previous version.  If you are installing from physical media like a DVD or USB, then copy it to your hard drive, then install from there.  Always make sure you have local admin rights, UAC is off, and antivirus is disabled.
Also, do a custom installation and do not install the service packs.
http://forums.autodesk.com/t5/Installation-Licensing/AutoCAD-2013-Suite-failed-installation-aborted-...
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Connect with Us
Twitter
Pinterest
Blog
Youtube
