i
We are having great trouble with installing AutoCad 2013 using GPO in AD. We have built the deployment from the wizard and merged the SP1.1 with the deployment. When running the link created by the deployment, AutoCad installs and everything is working ok both on W7-32 and W7-64. But when installing via AD, it seems that some part are missing and AutoCad will not start. We have used the gpo_for_sp1.mst that Hashim Mundol published on this forum. We have created installations of earlier versions of AutoCad the same way and with the same tools with succes, but 2013 is a hard nut. This is what our packing expert have written about our problems:
Hi!
We have trouble with deployment of AutoCad 2013 SP1 through Active Directory using GPO (Group Policies)
The deployment admin image is built with the deployment wizard, and the deployment settings in AD is done this way:
The installation appears to run fine, but when we start the application from the shortcut (or directly execute the main executable) absolutely nothing happens.
We have tried to rebuild several Administrative images, and tried a couple of different deploy settings In AD, but the result is always (always)the same.
In one scenario, if we open task manager – we can see that acad.exe is running for about 10 seconds and then quits without error messages.
In another scenario, absolutely nothing happens, and no acad.exe is seen in task manager at all.
Best Regards
Egil Johnsrud
Looking for some good advice.
Best regards
Kristian Ludvik-Böhmer
Senior Engineer
Norwegian Broadcasting Corporation
Sounds like a license registration failure to me. I suspect the adlm log will confirm this.
I'm sorry, but this is not about license registration, but about installation. When we apply the deployment in AD via Group Policy, the installation on the client computer is not complete. When we install the program but clicking the link created by the deployment everything is ok. We did not experience this problem with earlier versions of AutoCad.
Post the ADLM log. It's probably a license registration failure.
If the deployment runs with the shortcut created manually, then clearly the GPO is not set up correctly.
