• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    Active Member
    AutoCad 2012 display problem
    433 Views, 10 Replies
    10-18-2012 07:28 PM
    Dear All
    We have a problem from AutoCad 2012(64bit version)
    We right reference file, open new file and open laybox.
    The lay baybox show black serneen.
    We have many user have this issue.
    We using windows 7 64 bit pro
    We try to upgrade display card driver to latest version. But still have problem.
    And black scrneen only from AutoCad.
    Other software is working.
    We confirm this is AutoCad problem
    Anyone have idea?
    Below is the error for your information
    Thank you
    Ming
    This is AutoCad 2012 version
    Please use plain text.
    *Expert Elite*
    TravisNave
    Re: AutoCad 2012 display problem
    10-19-2012 08:02 AM in reply to: mingpak8031
    What is your video card and driver?
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    Active Member
    10-21-2012 09:14 PM in reply to: TravisNave
    We using NVIDIA Quadro 4000 display card.
    And using from nvidia driver.
    This is the link for your information
    Link: http://www.nvidia.com/object/quadro-tesla-win8-win7-winvista-64bit-306.79-whql-driver.html
    Thank you
    Ming
    Product Support
    10-21-2012 11:37 PM in reply to: mingpak8031
    Have you tried to turn on Hardware accelerator?
    Please check up the Adaptive degralatation and check the graphics card update manually from software.
    Yong Jing
    Product Support Specialist
    Frontline Technical Support, CSS. GCSO
    Active Member
    10-25-2012 02:01 AM in reply to: jingy
    Hello.
    I check autocad setting.
    Our Autocad already trun on this function.
    Ming
    Product Support
    10-25-2012 08:32 PM in reply to: mingpak8031
    Is there possible to provide your system infomation *.nfo file to us?
    Yong Jing
    Active Member
    10-25-2012 08:48 PM in reply to: jingy
    Hello
    How to get the *.nfo file?
    Could you give me the step?
    Product Support
    10-25-2012 09:22 PM in reply to: mingpak8031
    In Windows Run, input msinfo32,exe, then click it to open System Infomation.
    In System Infomation dialogbox, click File >Save, then save the *.nfo files
    Yong Jing
    Active Member
    10-29-2012 01:19 AM in reply to: jingy
    Hello
    The attachmnet is our PC .nfo file for your information
    Ming
    Active Member
    11-12-2012 01:02 AM in reply to: mingpak8031
    Hello All
    Any idea about it?
    Thank you
    Ming
