• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    *Expert Elite*
    TravisNave
    Re: AutoCad 2011 Will not open up on computer
    04-30-2012 02:09 PM in reply to: njohnson
    Yeah, the license is bad.  Try the steps here:
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15176093&linkID=9240617
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    Please use plain text.
    New Member
    12-13-2012 12:30 PM in reply to: TravisNave
    I have this problem too but the suggested fix won't work for me. AutoCAD 2012 still runs fine but the AutoCAD 2011 which I downloaded today will not launch, in the same way as described by users in this thread.
    I cannot check the ADLM file or rename the FLEXnet file because in my PC (XP, 32 bit) the file tree is not as described in your fix.
    Your fix says C:\Documents and Settings\All Users\Application Data\Autodesk\ADLM
    In the 'run' box, I try to open C:\Documents and Settings\All Users\Application Data\Autodesk\ADLM but I get
    "Windows cannot find 'C:\ Documents'. Please make sure you typed correctly... "
    However, I can get as far as the application data folder if I cut the last two items off
    but that application data folder does not contain a folder or file called Autodesk or AutoCAD.
    I had expected to be prompted to verify my license the first time I launched but there was no such prompt.
    Please can you suggest anything? Thanks.
    New Member
    12-18-2012 03:35 PM in reply to: TravisNave
    Nudging my question to top.
