Installation & Licensing
AutoCad 2011 Will not open up on computer
12 REPLIES 12
Message 1 of 13
1252 Views, 12 Replies
Hello I recently downloaded the student AutoCad 2012 program which works fine on my laptop. I then tried to download the 2011 student AutoCad from the website but it will not open when I click on the icon. I have tried twice to download it both with the same results. I unistalled all the files before trying to reinstall it again the second time. I have Windows 7    64-bit operating system with service pack 1. It is a brand new laptop and I have nothing else on it except for these 2 AutoCad programs. I read the read me for it numerous times and it looks like I have all the system requirements.It is an Acer laptop and says there is still 7.85GB left of usable RAM.I have the newest version of Adobe Reader 9 installed. It appears to try to open when I click on it but then after it says opening autocad 2011 it closes itself immediately.Any suggestions as to why it wont open? Thanks much appreciated!
David
12 REPLIES 12
Message 2 of 13
Patchy
Nobody giving out the 2011anymore when 2012 is out.
Message 3 of 13
I'm having the same problem. We have to use 2011 for this class I'm taking.
Message 4 of 13
arlinpega.bibat
Hi dsinclair6:
Thank you for bringing this into our attention. We will need to have a look into it and will let you know for updates.
Thank you!
Arlin Bibat
Message 5 of 13
arlinpega.bibat
Hi dsinclair6:
The 2011 version should still run on your machine even when a 2012 version is currently installed. After you have downloaded it, you were prompted to have it installed. Coudl you possibly provide us a screen shot of the error so we may have visibility? If you could provide any other detailed information, we would greatly appreciate it.
Thank you!
Arlin Bibat
Message 6 of 13
in reply to: arlinpega.bibat
I have the same issue, trying desperately to install AutoCAD 2011, installs good, but when you try to open, it closes it's self down.  How do I fix this?????????
Message 7 of 13
TravisNave
Sounds like a corrupted CascadeInfo.cas file.
For more detailed information about the CascadeInfo.cas file, please refer to the Autodesk Support Knowledge Base article found here:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?linkID=9240617&id=13894457&siteID=123112
Autodesk Forums:
Message 8 of 13
in reply to: TravisNave
Guru, i tried renaming the file, and then tried to start autocad again, and it shut it's self down again, and also recreated the CascadeInfo.cas file.  What else can i try????????
Message 9 of 13
TravisNave
Let me know what is in the ADLM log file in that same folder.  You can post it here.  It may have the reason for the failure.
Autodesk Forums:
Message 10 of 13
3576 2012/04/03 13:09:20 Reason=Fatal error 3576 2012/04/03 13:09:20 ComputerName=ALAND 3576 2012/04/03 13:09:20 OS=6.1.7601.Service Pack 1 3576 2012/04/03 13:09:20 File=AdlmIntSATSLicense.cpp,Line=1150 3576 2012/04/03 13:09:20 AdlmIntError=38 [Error getting license usage and behavior] 5044 2012/04/03 13:10:21 Reason=Fatal error 5044 2012/04/03 13:10:21 ComputerName=ALAND 5044 2012/04/03 13:10:21 OS=6.1.7601.Service Pack 1 5044 2012/04/03 13:10:21 File=AdlmIntSATSLicense.cpp,Line=1150 5044 2012/04/03 13:10:21 AdlmIntError=38 [Error getting license usage and behavior] 4908 2012/04/03 13:11:10 Reason=Fatal error 4908 2012/04/03 13:11:10 ComputerName=ALAND 4908 2012/04/03 13:11:10 OS=6.1.7601.Service Pack 1 4908 2012/04/03 13:11:10 File=AdlmIntSATSLicense.cpp,Line=1150 4908 2012/04/03 13:11:10 AdlmIntError=38 [Error getting license usage and behavior] 3704 2012/04/03 13:11:11 Reason=Fatal error 3704 2012/04/03 13:11:11 ComputerName=ALAND 3704 2012/04/03 13:11:11 OS=6.1.7601.Service Pack 1 3704 2012/04/03 13:11:11 File=AdlmIntSATSLicense.cpp,Line=1150 3704 2012/04/03 13:11:11 AdlmIntError=38 [Error getting license usage and behavior] 536 2012/04/03 13:11:22 Reason=Fatal error 536 2012/04/03 13:11:22 ComputerName=ALAND 536 2012/04/03 13:11:22 OS=6.1.7601.Service Pack 1 536 2012/04/03 13:11:22 File=AdlmIntSATSLicense.cpp,Line=1150 536 2012/04/03 13:11:22 AdlmIntError=38 [Error getting license usage and behavior] 3320 2012/04/03 13:11:46 Reason=Fatal error 3320 2012/04/03 13:11:46 ComputerName=ALAND 3320 2012/04/03 13:11:46 OS=6.1.7601.Service Pack 1 3320 2012/04/03 13:11:46 File=AdlmIntSATSLicense.cpp,Line=1150 3320 2012/04/03 13:11:46 AdlmIntError=38 [Error getting license usage and behavior] 3932 2012/04/06 15:18:39 Reason=Fatal error 3932 2012/04/06 15:18:39 ComputerName=ALAND 3932 2012/04/06 15:18:39 OS=6.1.7601.Service Pack 1 3932 2012/04/06 15:18:39 File=AdlmIntSATSLicense.cpp,Line=1150 3932 2012/04/06 15:18:39 AdlmIntError=38 [Error getting license usage and behavior] 4284 2012/04/06 15:35:55 Reason=Fatal error 4284 2012/04/06 15:35:55 ComputerName=ALAND 4284 2012/04/06 15:35:55 OS=6.1.7601.Service Pack 1 4284 2012/04/06 15:35:55 File=AdlmIntSATSLicense.cpp,Line=1150 4284 2012/04/06 15:35:55 AdlmIntError=38 [Error getting license usage and behavior] 4996 2012/04/17 13:20:54 Reason=Fatal error 4996 2012/04/17 13:20:54 ComputerName=ALAND 4996 2012/04/17 13:20:54 OS=6.1.7601.Service Pack 1 4996 2012/04/17 13:20:54 File=AdlmIntSATSLicense.cpp,Line=1150 4996 2012/04/17 13:20:54 AdlmIntError=38 [Error getting license usage and behavior] 4104 2012/04/17 13:21:05 Reason=Fatal error 4104 2012/04/17 13:21:05 ComputerName=ALAND 4104 2012/04/17 13:21:05 OS=6.1.7601.Service Pack 1 4104 2012/04/17 13:21:05 File=AdlmIntSATSLicense.cpp,Line=1150 4104 2012/04/17 13:21:05 AdlmIntError=38 [Error getting license usage and behavior] 1860 2012/04/18 08:13:10 Reason=Fatal error 1860 2012/04/18 08:13:10 ComputerName=ALAND 1860 2012/04/18 08:13:10 OS=6.1.7601.Service Pack 1 1860 2012/04/18 08:13:10 File=AdlmIntSATSLicense.cpp,Line=1150 1860 2012/04/18 08:13:10 AdlmIntError=38 [Error getting license usage and behavior] 5084 2012/04/18 08:13:40 Reason=Fatal error 5084 2012/04/18 08:13:40 ComputerName=ALAND 5084 2012/04/18 08:13:40 OS=6.1.7601.Service Pack 1 5084 2012/04/18 08:13:40 File=AdlmIntSATSLicense.cpp,Line=1150 5084 2012/04/18 08:13:40 AdlmIntError=38 [Error getting license usage and behavior] 4728 2012/04/18 08:13:58 Reason=Fatal error 4728 2012/04/18 08:13:58 ComputerName=ALAND 4728 2012/04/18 08:13:58 OS=6.1.7601.Service Pack 1 4728 2012/04/18 08:13:58 File=AdlmIntSATSLicense.cpp,Line=1150 4728 2012/04/18 08:13:58 AdlmIntError=38 [Error getting license usage and behavior] 4400 2012/04/18 08:26:59 Reason=Fatal error 4400 2012/04/18 08:26:59 ComputerName=ALAND 4400 2012/04/18 08:26:59 OS=6.1.7601.Service Pack 1 4400 2012/04/18 08:26:59 File=AdlmIntSATSLicense.cpp,Line=1150 4400 2012/04/18 08:26:59 AdlmIntError=38 [Error getting license usage and behavior] 3464 2012/04/18 08:23:24 Reason=Fatal error 3464 2012/04/18 08:23:24 ComputerName=ALAND 3464 2012/04/18 08:23:24 OS=6.1.7601.Service Pack 1 3464 2012/04/18 08:23:24 File=AdlmIntSATSLicense.cpp,Line=1150 3464 2012/04/18 08:23:24 AdlmIntError=38 [Error getting license usage and behavior] 2712 2012/04/18 09:01:49 Reason=Fatal error 2712 2012/04/18 09:01:49 ComputerName=ALAND 2712 2012/04/18 09:01:49 OS=6.1.7601.Service Pack 1 2712 2012/04/18 09:01:49 File=AdlmIntSATSLicense.cpp,Line=1150 2712 2012/04/18 09:01:49 AdlmIntError=38 [Error getting license usage and behavior] 4760 2012/04/18 12:02:59 Reason=Fatal error 4760 2012/04/18 12:02:59 ComputerName=ALAND 4760 2012/04/18 12:02:59 OS=6.1.7601.Service Pack 1 4760 2012/04/18 12:02:59 File=AdlmIntSATSLicense.cpp,Line=1150 4760 2012/04/18 12:02:59 AdlmIntError=38 [Error getting license usage and behavior] 4444 2012/04/27 15:06:30 Reason=Fatal error 4444 2012/04/27 15:06:30 ComputerName=ALAND 4444 2012/04/27 15:06:30 OS=6.1.7601.Service Pack 1 4444 2012/04/27 15:06:30 File=AdlmIntSATSLicense.cpp,Line=1150 4444 2012/04/27 15:06:30 AdlmIntError=38 [Error getting license usage and behavior] 3104 2012/04/27 15:06:47 Reason=Fatal error 3104 2012/04/27 15:06:47 ComputerName=ALAND 3104 2012/04/27 15:06:47 OS=6.1.7601.Service Pack 1 3104 2012/04/27 15:06:47 File=AdlmIntSATSLicense.cpp,Line=1150 3104 2012/04/27 15:06:47 AdlmIntError=38 [Error getting license usage and behavior] 4188 2012/04/27 15:07:14 Reason=Fatal error 4188 2012/04/27 15:07:14 ComputerName=ALAND 4188 2012/04/27 15:07:14 OS=6.1.7601.Service Pack 1 4188 2012/04/27 15:07:14 File=AdlmIntSATSLicense.cpp,Line=1150 4188 2012/04/27 15:07:14 AdlmIntError=38 [Error getting license usage and behavior] 2360 2012/04/27 15:07:14 Reason=Fatal error 2360 2012/04/27 15:07:14 ComputerName=ALAND 2360 2012/04/27 15:07:14 OS=6.1.7601.Service Pack 1 2360 2012/04/27 15:07:14 File=AdlmIntSATSLicense.cpp,Line=1150 2360 2012/04/27 15:07:14 AdlmIntError=38 [Error getting license usage and behavior] 3024 2012/04/27 15:07:55 Reason=Fatal error 3024 2012/04/27 15:07:55 ComputerName=ALAND 3024 2012/04/27 15:07:55 OS=6.1.7601.Service Pack 1 3024 2012/04/27 15:07:55 File=AdlmIntSATSLicense.cpp,Line=1150 3024 2012/04/27 15:07:55 AdlmIntError=38 [Error getting license usage and behavior] 4840 2012/04/27 15:27:04 Reason=Fatal error 4840 2012/04/27 15:27:04 ComputerName=ALAND 4840 2012/04/27 15:27:04 OS=6.1.7601.Service Pack 1 4840 2012/04/27 15:27:04 File=AdlmIntSATSLicense.cpp,Line=1150 4840 2012/04/27 15:27:04 AdlmIntError=38 [Error getting license usage and behavior] 4972 2012/04/27 15:38:55 Reason=Fatal error 4972 2012/04/27 15:38:55 ComputerName=ALAND 4972 2012/04/27 15:38:55 OS=6.1.7601.Service Pack 1 4972 2012/04/27 15:38:55 File=AdlmIntSATSLicense.cpp,Line=1150 4972 2012/04/27 15:38:55 AdlmIntError=38 [Error getting license usage and behavior] 3344 2012/04/30 11:20:39 Reason=Fatal error 3344 2012/04/30 11:20:39 ComputerName=ALAND 3344 2012/04/30 11:20:39 OS=6.1.7601.Service Pack 1 3344 2012/04/30 11:20:39 File=AdlmIntSATSLicense.cpp,Line=1150 3344 2012/04/30 11:20:39 AdlmIntError=38 [Error getting license usage and behavior] 4072 2012/04/30 12:07:22 Reason=Fatal error 4072 2012/04/30 12:07:22 ComputerName=ALAND 4072 2012/04/30 12:07:22 OS=6.1.7601.Service Pack 1 4072 2012/04/30 12:07:22 File=AdlmIntSATSLicense.cpp,Line=1150 4072 2012/04/30 12:07:22 AdlmIntError=38 [Error getting license usage and behavior] 3648 2012/04/30 12:07:46 Reason=Fatal error 3648 2012/04/30 12:07:46 ComputerName=ALAND 3648 2012/04/30 12:07:46 OS=6.1.7601.Service Pack 1 3648 2012/04/30 12:07:46 File=AdlmIntSATSLicense.cpp,Line=1150 3648 2012/04/30 12:07:46 AdlmIntError=38 [Error getting license usage and behavior] 3852 2012/04/30 12:09:42 Reason=Fatal error 3852 2012/04/30 12:09:42 ComputerName=ALAND 3852 2012/04/30 12:09:42 OS=6.1.7601.Service Pack 1 3852 2012/04/30 12:09:42 File=AdlmIntSATSLicense.cpp,Line=1150 3852 2012/04/30 12:09:42 AdlmIntError=38 [Error getting license usage and behavior] 3940 2012/04/30 12:10:04 Reason=Fatal error 3940 2012/04/30 12:10:04 ComputerName=ALAND 3940 2012/04/30 12:10:04 OS=6.1.7601.Service Pack 1 3940 2012/04/30 12:10:04 File=AdlmIntSATSLicense.cpp,Line=1150 3940 2012/04/30 12:10:04 AdlmIntError=38 [Error getting license usage and behavior] 2716 2012/04/30 12:10:42 Reason=Fatal error 2716 2012/04/30 12:10:42 ComputerName=ALAND 2716 2012/04/30 12:10:42 OS=6.1.7601.Service Pack 1 2716 2012/04/30 12:10:42 File=AdlmIntSATSLicense.cpp,Line=1150 2716 2012/04/30 12:10:42 AdlmIntError=38 [Error getting license usage and behavior] 3748 2012/04/30 12:11:17 Reason=Fatal error 3748 2012/04/30 12:11:17 ComputerName=ALAND 3748 2012/04/30 12:11:17 OS=6.1.7601.Service Pack 1 3748 2012/04/30 12:11:17 File=AdlmIntSATSLicense.cpp,Line=1150 3748 2012/04/30 12:11:17 AdlmIntError=38 [Error getting license usage and behavior] 3612 2012/04/30 12:11:18 Reason=Fatal error 3612 2012/04/30 12:11:18 ComputerName=ALAND 3612 2012/04/30 12:11:18 OS=6.1.7601.Service Pack 1 3612 2012/04/30 12:11:18 File=AdlmIntSATSLicense.cpp,Line=1150 3612 2012/04/30 12:11:18 AdlmIntError=38 [Error getting license usage and behavior] 3836 2012/04/30 12:11:18 Reason=Fatal error 3836 2012/04/30 12:11:18 ComputerName=ALAND 3836 2012/04/30 12:11:18 OS=6.1.7601.Service Pack 1 3836 2012/04/30 12:11:18 File=AdlmIntSATSLicense.cpp,Line=1150 3836 2012/04/30 12:11:18 AdlmIntError=38 [Error getting license usage and behavior] 1224 2012/04/30 12:12:51 Reason=Fatal error 1224 2012/04/30 12:12:51 ComputerName=ALAND 1224 2012/04/30 12:12:51 OS=6.1.7601.Service Pack 1 1224 2012/04/30 12:12:51 File=AdlmIntSATSLicense.cpp,Line=1150 1224 2012/04/30 12:12:51 AdlmIntError=38 [Error getting license usage and behavior] 968 2012/04/30 12:13:25 Reason=Fatal error 968 2012/04/30 12:13:25 ComputerName=ALAND 968 2012/04/30 12:13:25 OS=6.1.7601.Service Pack 1 968 2012/04/30 12:13:25 File=AdlmIntSATSLicense.cpp,Line=1150 968 2012/04/30 12:13:25 AdlmIntError=38 [Error getting license usage and behavior] 4388 2012/04/30 12:14:13 Reason=Fatal error 4388 2012/04/30 12:14:13 ComputerName=ALAND 4388 2012/04/30 12:14:13 OS=6.1.7601.Service Pack 1 4388 2012/04/30 12:14:13 File=AdlmIntSATSLicense.cpp,Line=1150 4388 2012/04/30 12:14:13 AdlmIntError=38 [Error getting license usage and behavior] 3120 2012/04/30 12:19:31 Reason=Fatal error 3120 2012/04/30 12:19:31 ComputerName=ALAND 3120 2012/04/30 12:19:31 OS=6.1.7601.Service Pack 1 3120 2012/04/30 12:19:31 File=AdlmIntSATSLicense.cpp,Line=1150 3120 2012/04/30 12:19:31 AdlmIntError=38 [Error getting license usage and behavior] 4712 2012/04/30 12:38:49 Reason=Fatal error 4712 2012/04/30 12:38:49 ComputerName=ALAND 4712 2012/04/30 12:38:49 OS=6.1.7601.Service Pack 1 4712 2012/04/30 12:38:49 File=AdlmIntSATSLicense.cpp,Line=1150 4712 2012/04/30 12:38:49 AdlmIntError=38 [Error getting license usage and behavior] 4584 2012/04/30 12:43:34 Reason=Fatal error 4584 2012/04/30 12:43:34 ComputerName=ALAND 4584 2012/04/30 12:43:34 OS=6.1.7601.Service Pack 1 4584 2012/04/30 12:43:34 File=AdlmIntSATSLicense.cpp,Line=1150 4584 2012/04/30 12:43:34 AdlmIntError=38 [Error getting license usage and behavior] 3052 2012/04/30 12:43:54 Reason=Fatal error 3052 2012/04/30 12:43:54 ComputerName=ALAND 3052 2012/04/30 12:43:54 OS=6.1.7601.Service Pack 1 3052 2012/04/30 12:43:54 File=AdlmIntSATSLicense.cpp,Line=1150 3052 2012/04/30 12:43:54 AdlmIntError=38 [Error getting license usage and behavior] 4296 2012/04/30 12:44:09 Reason=Fatal error 4296 2012/04/30 12:44:09 ComputerName=ALAND 4296 2012/04/30 12:44:09 OS=6.1.7601.Service Pack 1 4296 2012/04/30 12:44:09 File=AdlmIntSATSLicense.cpp,Line=1150 4296 2012/04/30 12:44:09 AdlmIntError=38 [Error getting license usage and behavior] 4028 2012/04/30 12:44:24 Reason=Fatal error 4028 2012/04/30 12:44:24 ComputerName=ALAND 4028 2012/04/30 12:44:24 OS=6.1.7601.Service Pack 1 4028 2012/04/30 12:44:24 File=AdlmIntSATSLicense.cpp,Line=1150 4028 2012/04/30 12:44:24 AdlmIntError=38 [Error getting license usage and behavior] 2928 2012/04/30 12:48:28 Reason=Fatal error 2928 2012/04/30 12:48:28 ComputerName=ALAND 2928 2012/04/30 12:48:28 OS=6.1.7601.Service Pack 1 2928 2012/04/30 12:48:28 File=AdlmIntSATSLicense.cpp,Line=1150 2928 2012/04/30 12:48:28 AdlmIntError=38 [Error getting license usage and behavior] 2460 2012/04/30 12:52:26 Reason=Fatal error 2460 2012/04/30 12:52:26 ComputerName=ALAND 2460 2012/04/30 12:52:26 OS=6.1.7601.Service Pack 1 2460 2012/04/30 12:52:26 File=AdlmIntSATSLicense.cpp,Line=1150 2460 2012/04/30 12:52:26 AdlmIntError=38 [Error getting license usage and behavior] 5040 2012/04/30 12:59:42 Reason=Fatal error 5040 2012/04/30 12:59:42 ComputerName=ALAND 5040 2012/04/30 12:59:42 OS=6.1.7601.Service Pack 1 5040 2012/04/30 12:59:42 File=AdlmIntSATSLicense.cpp,Line=1150 5040 2012/04/30 12:59:42 AdlmIntError=38 [Error getting license usage and behavior]
Message 11 of 13
TravisNave
Yeah, the license is bad.  Try the steps here:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15176093&linkID=9240617
Autodesk Forums:
Message 12 of 13
I have this problem too but the suggested fix won't work for me. AutoCAD 2012 still runs fine but the AutoCAD 2011 which I downloaded today will not launch, in the same way as described by users in this thread.
I cannot check the ADLM file or rename the FLEXnet file because in my PC (XP, 32 bit) the file tree is not as described in your fix.
Your fix says C:\Documents and Settings\All Users\Application Data\Autodesk\ADLM
In the 'run' box, I try to open C:\Documents and Settings\All Users\Application Data\Autodesk\ADLM but I get
"Windows cannot find 'C:\ Documents'. Please make sure you typed correctly... "
However, I can get as far as the application data folder if I cut the last two items off
but that application data folder does not contain a folder or file called Autodesk or AutoCAD.
I had expected to be prompted to verify my license the first time I launched but there was no such prompt.
Please can you suggest anything? Thanks.
Message 13 of 13
Nudging my question to top.
Administrator Productivity
