Installation & Licensing
TravisNave
Message 11 of 13 (448 Views)
Re: AutoCad 2011 Will not open up on computer
04-30-2012 02:09 PM in reply to: njohnson
Yeah, the license is bad.  Try the steps here:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15176093&linkID=9240617
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
New Member
Message 12 of 13 (352 Views)
12-13-2012 12:30 PM in reply to: TravisNave
I have this problem too but the suggested fix won't work for me. AutoCAD 2012 still runs fine but the AutoCAD 2011 which I downloaded today will not launch, in the same way as described by users in this thread.
I cannot check the ADLM file or rename the FLEXnet file because in my PC (XP, 32 bit) the file tree is not as described in your fix.
Your fix says C:\Documents and Settings\All Users\Application Data\Autodesk\ADLM
In the 'run' box, I try to open C:\Documents and Settings\All Users\Application Data\Autodesk\ADLM but I get
"Windows cannot find 'C:\ Documents'. Please make sure you typed correctly... "
However, I can get as far as the application data folder if I cut the last two items off
but that application data folder does not contain a folder or file called Autodesk or AutoCAD.
I had expected to be prompted to verify my license the first time I launched but there was no such prompt.
Please can you suggest anything? Thanks.
New Member
Message 13 of 13 (323 Views)
12-18-2012 03:35 PM in reply to: TravisNave
Nudging my question to top.
You are not logged in.
Ask the Community
Connect with Us
Twitter
Pinterest
Blog
Youtube
