I´m soon to install AutoDesk Design Master with a lot of apps, but the location I´m using to create config ini files on is not connected to the license server, so therefor during make of the deployment ini file I use my hostname, and wanted to thenge the license mode after in the config file, but I cannot find it. Help!
A workaround can be to set an entry in the host file and there specify the hostname of the license server 127.0.0.1, only to be able to get the correct hostname in the package? Cause if the deployment wizard cannot find the specified license server I cannot continue.
Comments?
/Göran
Found it in the mst in the property table looking like this:
ACADSERVERPATH pc3 000000000000
My hostname is pc3 - so I guess it is just to replace it with my license server name in Orca? - Or?
