Installation & Licensing
mezuk04
215 Views, 1 Reply
AutoCad 2008 to 2006
I have produced a drawing in AutoCad 2008 LT at work, I have returned the works laptop that had CAD on it. In order to work with the drawing I have brought in my own laptop in which has AutoCad 2006 LT. I tried to open up the drawing in 2006 but it informs me it cant.
How do I make it compatible? Now that I dont have access to 2008
Regards
Chris
1 REPLY 1
vivekramesh
in reply to: mezuk04
AutoCAD drawings are forward compatible only.
The drawing you have must be saved as a 2007 file format and hence is unreadable in AutoCAD 2006.
You need to get the drawing to open in AutoCAD 2008 or later and save the file as a 2004 version file.
Only then will you be able to work with the drawing using AutoCAD LT 2006.
Vivek Ramesh
Autodesk Product Support
Vivek Ramesh
Product Support Specialist
Global Services
Autodesk, Inc.
Administrator Productivity
