• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    Member
    pike14130
    AutoCADLT 2012 Won't display after ribbon load
    161 Views, 3 Replies
    02-04-2012 08:30 AM
    Prior to purchasing AUToCADLT 2012 I used their trial 32bit version download (December 2011), worked great. I then  purchased ACADLT 2012 as standalone license using the DVD install. Prior to the DVD install,  I uninstalled the trial version, using WINXP uninstall software through control panel. On the Online support , there is "How To uninstall AutoCAd previous versions". Following the instructions, delected APP folder references, I then went into the registry and deleted the HK local machine and users entry . Used CCleaner to delete any unreferenced items, and verify AUTOCad "crumbs" were out of the system.
    I then installed The Standalone  32bit DVD version, inserting the product  and license  code, downloaded and performed SP1 update, downloaded and swapped out Ribbon fix items, worked great.... for about 1 week, then when ribbon tried to load, Autocad would disappear from screen . Thinking I had a Licensing conflict issue, it would work powering the machine on and off for a week,  I performed the uninstall and install  operation 2xs since then. I contacted licensing support, they emailed me back that it wasn't a licensing issue. Searched through discussion groups for similar problems, none found. After @ 6weeks of "usuage", need to fix this, it is distracting me from my consulting business. Help would be greatly appreciated
    Member
    pike14130
    Re: AutoCADLT 2012 Won't display after ribbon load
    02-04-2012 09:45 PM in reply to: pike14130
    As aside note, I did some further digginging into the .log files and found fileACDLT2012ENUAdlm.log showing:
    3532    2012/02/05    00:13:44    Reason=Fatal error
    3532    2012/02/05    00:13:44    ComputerName=MYPIG
    3532    2012/02/05    00:13:44    OS=5.1.2600.Service Pack 3
    3532    2012/02/05    00:13:44    File=AdlmIntSATSLicense.cpp,Line=2164
    3532    2012/02/05    00:13:44    AdlmIntError=17 [The license was not found]
     Which mystifies me. This product was purchased from Amazon, which is a Autodesk vendor. The DVD package was sealed, yet I may not have a valid license. Anybody got any clues on who I need to contact to get this straightened out?
    ***Guru
    TravisNave
    02-06-2012 11:31 AM in reply to: pike14130
    You might need to blow away your license files and reactivate.
    Delete the following files if you have Windows 7:
    C:\ProgramData\flexnet\adsk*.data
    or on Windows XP:
    C:\Documents and Settings\All Users\Application Data\flexnet\adsk*.data
    The folders are hidden, so either turn on hidden folders or traverse the folder structure manually in the address bar.
    Additionally, if you have a corrupt CascadeInfo.cas file, you might consider deleting it.  Usually though this only affects network seats:
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?linkID=9240617&id=13894457&siteID=123112
    My Top Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Administrator | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combining .LIC Files | Search Autodesk Discussion Groups
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    Member
    pike14130
    02-07-2012 04:37 PM in reply to: TravisNave
    After the licensing and activation folks wanted to me to send them a screen shot of the nonexistant Ribbon screen, I again wiped the computer clean of all Autodesk files, as described in previous posts. After a few attempts to register and activate, Ribbon now seems to be working correctly. I then performed then Updated with SP1 and Ribbon Hot fixes, keeping my fingers crossed at this point.
    TravisNav, I did delete Flexnet folders prior to new install. Hope this time everything starts correctly. Thanks
