Installation & Licensing
2389 Views, 5 Replies
AutoCAD wont install
When i open the installer for AutoCAD 2011, it tells me that AutoCAD 2011 is already installed and it wont let me check it to install. How do i install it?
5 REPLIES 5
pendean
Why would it think it's already installed? Did you have a demo on the same machine?
DouglasLauritsen
If you had previously had AutoCAD 2011 installed this may happen. Is AutoCAD 2011 listed in the Add and Remove programs or Programs and Features list? If so try uninstalling it or follow Travis’ advice on using he Windows Installer CleanUp Utility in this thread. The Revo Uninstaller is another popular alternative. It is mentioned in this other thread as well.
If you continue to have trouble let us know.
Douglas Lauritsen, Autodesk Product Support
Douglas Lauritsen
Support Specialist
Product Support
Autodesk, Inc.
I'm having the same problem.  AutoCAD 2011 is not listed in Control Panel>Add/remove programs.  I have gone through this entire process:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617
which deletes registry entries, program files, common files, almost any thing I can imagine that would have a trace of an AutoCAD file in it.  Still nothing.  I went as far as deleting every search result I could find with the words autocad. Still when I try to download an educational version of autocad 2011 its says autocad is still installed... help
I would like to add that i have had a demo of autocad 2011 in the past
Administrator Productivity
