• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    Member
    AutoCAD won't load no matter what!
    192 Views, 3 Replies
    01-17-2013 01:23 PM
    The program crashed whilst I was working on it, now every time I open the software a box just appears saying 'AutoCAD Erorr Reoprt' and asks me to provide feedback to their error report. The actual program will not open even after restarting my computer, uninstalling the software and re-installing it.
    Can anyone shed any light on how to solve this problem??
    Thanks!
    Please use plain text.
    *Expert Elite*
    TravisNave
    Re: AutoCAD won't load no matter what!
    01-17-2013 02:40 PM in reply to: willhope87
    First I would try a system restore back to a day when it worked.  If that doesn't solve it, uninstall it and then reinstall.
    Active Member
    01-17-2013 02:55 PM in reply to: willhope87
    What version of AutoCAD?
    Have you tried logging in as a different user?
    Make sure your User Account Control is disabled for the new user before starting AutoCAD
    1.  Click on the Windows Start button
    2.  In the search box enter "change user"
    3.  From the list you should see a flag icon at the top with the name "Change User Account Control"
    4.  Move the slider all the way to the bottom (never notify)
    5.  It is recommended that you restart your computer for this change to take effect.
    Also try deleting the WSCommCntrData.xml file from the following location.  C:\Users\<username>\AppData\Local\Autodesk\AutoCAD 2013 - English\R19.0\WebServices
    _____________________________
    A2K Technologies Support Team
    www.a2ktechnologies.com.au
    Product Support
    01-18-2013 12:09 PM in reply to: willhope87
    willhope87,
    Hello. It sounds like you have a corrupt installation or a graphics card conflict. Let’s check the graphics card:
    1.) Right-click the program icon on your desktop
    2.) Click "Properties"
    3.) Access the "Shortcut" tab
    4.) In the "Target" field, after acadlt.exe" type a space and then /NOHARDWARE
    5.) Click "OK" and retest
    If this works, you have a graphics card driver conflict. Install a different driver and then remove this switch and see if it helps.
    If you have a corrupt installation, you should uninstall through the control panel and then delete the program folders in these locations (they should be clearly named):
    C:\Program Files\Autodesk\
    C:\ProgramData\Autodesk\
    C:\Program Files (x86)\Autodesk\
    C:\Users\All Users\Autodesk\
    C:\Users\**YOUR USERID**\AppData\Roaming\Autodesk\
    C:\Users\**YOUR USERID**\AppData\Local\Autodesk\
    After these are deleted, I would reinstall as an admin with UAC and antivirus turned off.
    Thank you for taking part in our community!
    David Dembkoski
    Product Support Specialist
    Autodesk Product Support
