We have to realize a significant problem with AutoCAD.
When we launch the software and there are no available licenses the process continues to run.
This greatly slows computers !!
Do you have a solution?
Hello. Make sure you are on the latest service packs for your version. I have seen this occasionally with our older versions, but it has been a while.
I would make sure the service packs are all installed first, and then see if the behavior recurs. If it does, is it on ALL machines or just some machines?
I have seen some older posts mentioning the communication center causing a hang:
Thank you for taking part in our community!
