Installation & Licensing
rkrimou
305 Views, 1 Reply
AutoCAD process
We have to realize a significant problem with AutoCAD.
When we launch the software and there are no available licenses the process continues to run.
This greatly slows computers !!
Do you have a solution?
1 REPLY 1
dembkod
in reply to: rkrimou
rkrimou,
Hello. Make sure you are on the latest service packs for your version. I have seen this occasionally with our older versions, but it has been a while.
I would make sure the service packs are all installed  first, and then see if the behavior recurs. If it does, is it on ALL machines or just some machines?
I have seen some older posts mentioning the communication center causing a hang:
http://forums.autodesk.com/t5/AutoCAD-Land-Desktop/ldd-acad-exe-will-not-stop-running-upon-exit/td-p...
Thank you for taking part in our community!
David Dembkoski
Administrator Productivity
