I tried to download the student version of AutoCAD 2013. When I got to the installation wizard I entered the serial # and product code for AutoCAD. The wizard shows a green check-mark for Autodesk Inventor Fusion 2013 installed, but AutoCAD shows a circle/slash and will not allow me to check the box (see attached MS WORD file). When I hover it says AutoCAD 2013 English is installed but there is no desktop shortcut and the files are not there, and I can't find the AutoCAD application. I did NOT enter the Autodesk Inventor product key!
Where did AutoCAD go?
Hello Robert,
Have you checked / can you attach your installation log so that we can see exactly where it's failing?
I am having the exact same problem!!! I have even taken my computer to two different professionals and they were unable to figure out the problem. It is so frustrating..
Hi Bailey,
Did you look through your installation log as well?
