Installation & Licensing
AutoCAD commands not working after install
1 REPLY 1
Jroper
337 Views, 1 Reply
Problem running AutoCAD 2013 or 2011 on a Lenovo W530 (Win7)
In AutoCAD 2013, when entering a command on the command line, it will not execute after hitting enter.  Ribbon buttons appear inoperable also.  Strangely, I can enter commands on the Dynamic Input cursor.  Most basic commands appear to work, like line.  But certain commands that require a dialog box, such as Xref, Plot or Properties pallette will crash AutoCAD.  The Layer command gave an unhandled exception because of a null value in the JIT debug.
It does seem to point to .NET install problem.  I have uninstalled and reinstalled .NET 4 Client and Extension without success.  I have not tried C++.  I would like to see if I can narrow it down to a single component because I've seen this problem before and I want to elimiate the source.  Any recommendations?
1 REPLY 1
david.lau
in reply to: Jroper
I would uninstall AutoCAD and reinstall it using a browser download.  You can download it from the Virtual Agent (#3) here:
http://upandready.typepad.com/up_and_ready/2013/01/quick-start-downloads.html
I would also re-install your video driver.  The instructions are noted here:
http://upandready.typepad.com/up_and_ready/2013/08/tip-reinstalling-a-video-driver.html
Typically, JIT errors are video driver related.
http://upandready.typepad.com/up_and_ready/2011/09/autocad-family-jit-just-in-time-debugging-errors....
David Lau
Administrator Productivity
