Hi, downloaded was complete. Had some trouble with installing the program. How do I try and reinstall the program again?
Use Add/Remove programs in the Control Panel.
I did that. But where do I go to try and reinstall again? Thank you for your help.
If the product is removed, simply insert your disc 1 again. If you downloaded the program, just run the setup.exe from the extracted files location. If not, add/remove programs will allow you the option to repair.
Thank you. How do I run the setup.exe from the extracted files location? Sorry.
When you downloaded the program, to what location were the files extracted? This is where your setup.exe is.
