Installation & Licensing
Member
ywseo
Message 1 of 2 (132 Views)
AutoCAD Mechanical Delete
132 Views, 1 Replies
10-29-2013 07:55 PM
Add / Remove Programs in Control Panel to the AutoCAD Mechanical 2013 product other than how to delete the contents of the command like the following guide , Autodesk has been
But instead of products Autodesk Library2013, Faro, Autodesk Sync, Content service remains intact.
The problem msiexec / x {guid} with Autodesk Library2013, Faro , but the clear , Autodesk Sync, Content service is not cleared.
How do I delete the rest of the items also available?
Technical support of Autodesk products Answer:
msiexec / q / x {GUID}
Therefore, if you check the GUID of a product when it is replaced by . GUID of each product can be found in the following registry :
HKEY_LOCAL_MACHINE \ SOFTWARE \ Microsoft \ Windows \ CurrentVersion \ Uninstall
Mechanical 2013 the GUID {5783F2D7-B005-0000-0102-0060B0CE6BBA} , so the command to delete is as follows :
msiexec / q / x {5783F2D7-B005-0000-0102-0060B0CE6BBA}
Other Windows applications, also apply the same method can be haebosil . GUID values for different products , but does not provide a clean , user-friendly registry can be found .
Product Support
david.lau
Message 2 of 2 (56 Views)
Re: Autocrat Mechanical Delete
10-31-2013 08:57 AM in reply to: ywseo
You can also  try the clean install unutility noted here:
http://upandready.typepad.com/up_and_ready/2013/06/the-legendary-quick-uninstall-utility-for-autodes...
If you want to setup a command line install, I agree with the instructions provided.  It can be labour intensive.
David Lau
You are not logged in.
Announcements
Need installation help?
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
