• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    Active Member
    AutoCAD Mechanical 2011 takes Inventor RS 2011 license tokens
    57 Views, 5 Replies
    02-08-2012 08:27 AM
    We have several AutoCAD Mechanical and Inventor licenses declared in the same license file.
    We don't understand why but sometimes AutoCAD Mechanical takes an Inventor token (85569INVPRORS_2011_0F) even if some AutoCAD Mechanical 2011 (85545AMECH_PP_2011_0F) are free.
    The installation fo Autocad Mechanical comes from Autocad Mechanical, we didn't use those from Inventor.
    Did anybody get already this problem ?
    Thanks for your help
    /Frédéric
    **Master
    Re: AutoCAD Mechanical 2011 takes Inventor RS 2011 license tokens
    02-08-2012 08:37 AM in reply to: frederic.lavoue
    is mechanical being started up first or is inventor being started first on the same machine?
    or the people using mechanical only have mechanical installed?
    Active Member
    02-08-2012 08:39 AM in reply to: DarrenP
    The users have only Autocad Mechanical on their computers.
    ***Guru
    TravisNave
    02-08-2012 08:41 AM in reply to: frederic.lavoue
    Do those users that only have Mechanical installed even have a need for Routed Systems?  You could exclude them from accessing it via an adskflex.opt options file.
    Have you tried deleting the CascadeInfo.cas file yet and seeing if relaunching Mechanical will pull a Mechanical license?  Also, which license is listed first in the LIC file?
    My Top Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Administrator | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combining .LIC Files | Search Autodesk Discussion Groups
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    Active Member
    02-08-2012 09:18 AM in reply to: TravisNave
    No they have no need, the users are totally different.
    Is it possible to do easily (we have more that 250 users located in 60 sites) ?
    No I didn't try to delete CascadeInfo.cas file, I will do it.
    in the lic file :
    Autocad Cilvil 3D
    Inventor
    Autocad Map
    Autocad Electrical
    then
    Autocad Mechanical
    ***Guru
    TravisNave
    02-08-2012 09:19 AM in reply to: frederic.lavoue
    Try deleting the CascadeInfo.cas file first.
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?linkID=9240617&id=13894457&siteID=123112
    Then if that doesn't work, move the Mechanical license to the top of the LIC file and reread the license.
    If that still doesn't work, I will help you make an adskflex.opt file.
