I am unable to install AutoCAD Map 3D 2015 on my computer. I get the following error message:
"A newer version of this software is already installed."
I don't have it already installed on my computer. I am using Windows 8.1 and have only Autodesk Recap, AutoCAD 2015, 3dsMax, and 123d Catch installed currently. What might this be and how can I fix this?
Solved by nadia.dagnone. Go to Solution.
It was the Autodesk BIM 360 AutoCAD add in 64 bit that was preventing a sucessful install. I uninstalled the add in and re-installed it with the Map 3d installation. I have no idea if it is the same add in or if this is eventually going to cause me problems later, but it seems to be working fine for now.
Great job on getting everything figured out! Your solution is also greatly appreciated. Thanks!
Thank you for posting this. I had the same issue when trying to install AutoCAD Architecture 2015 today. Your post helped me!
