Installation & Licensing
AutoCAD Map 2012 stop working
0 REPLIES 0
Message 1 of 1
wesbird
538 Views, 0 Replies
Sorry to cross post this from Map.
I have AutoCAD Map 2010, 2011 and 2012 installed on my machine. I install 2013 a couple of monch ago. I think 2010 and 2012 still works at that time. one day my 2010 and 2012 suddenly stop working. I tried repair install, un install and re-install a couple time. all failed. I have to install AutoCAD 2010 (not Map 2010), which works fine. I'm not sure if related to Map 2013 I installed a couple days ago. here is the error message I got whenever I run 2012, I got this and crash
C:\Program Files\Autodesk\AutoCAD Map 3D 2012\acmapdmtask.arx cannot find a procedure that it needs.
AcRxDynamicLinker failed to load 'acmapdmtask.arx'
I uninstall 2012, clean, re-install 2012, in the installation process, I got this in the middle
Failed to find node: //configuration/Connect/VDrive in XML file: C:\Program Files (x86)\Autodesk\Content Service\Connect.Service.ContentService.exe.config, system error: -2147020584
It still install 2012 on my machine. but still the same error message and crash.
What could be the problem? Should I uninstall 2013 and try again?
Thank you so much
Wes
Windows 10 64 bit, AutoCAD (ACA, Map) 2023
0 REPLIES 0
Administrator Productivity
