AutoCAD MEP 2013 Error alert Low Memory and After a new Start Up Slowly or not open
Remark
- Preview objects 3D
-Change View 3D
FATAL ERROR:
11/19/2012 at 14:51:41.876 Drawing: D:\PROJECT-2012\Muang SA-AD CO.LTD\PATTAYA\พัทยาซอย3\00 แบบรวมพัทยาซอย 3.dwg
Tune log files
Performance Tuner Results Log
Version: 19.0.2.0
Date of Last Tune: 1/11/2555
Machine Configuration
Processor Speed : 2.9 GHz
RAM : 3287 MB
3D Device
Name : AMD Radeon HD 6570
Manufacturer : AMD
Chip set : Radeon HD 6570
Memory : 3422 MB
Driver : 8.17.0010.1124
Your machine contains a 3D Device that is not certified.
As more graphics cards and 3D display drivers are tested, they are added to a list on the Autodesk website.
You can check for updates and download the latest certification list at any time. Run the 3DCONFIG command and click the Check for Updates button.
Current application driver: Software
Current Effect Status:
Enhanced 3D Performance: Not recommended and off
Smooth display: Not available
Gooch shader: Software emulation in use
Per-pixel lighting: Not available
Full-shadow display: Not available
Texture compression: Not available
Advanced material effects: Not available
Available application drivers and effect support:
Software driver
Effect support:
Enhanced 3D Performance: Not applicable
Smooth display: Not applicable
Gooch shader: Software emulation only
Per-pixel lighting: Not applicable
Full-shadow display: Not applicable
Texture compression: Not applicable
Advanced material effects: Not applicable
Autodesk driver: Not Certified
Effect support:
Enhanced 3D Performance: Available
Smooth display: Available
Gooch shader: Available
Per-pixel lighting: Available
Full-shadow display: Available
Texture compression: Available
Advanced material effects: Available
