I am currently running Windows 7 x64 with MEP 2010 x64, Revit MEP 2010 x64, and Revit MEP 2011 x64.
MEP 2010 Was running fine for the first 3 days. After a fail when opening DWGs and resorting in a Blue screen and system restart, the program has failed to open.
We have tried to repair, unistall, and reinstall. But still the same thing.
Sometimes it just opens and then closes and sometimes I get a "Command LIne- Close" dialog box, but nothing behind it. No matter what choice I make it just closes.
Please Help.
Justin
Solved by TravisNave. Go to Solution.
Try renaming the CascadeInfo.cas file located in the hidden folder at C:\ProgramData\Autodesk\Adlm
Then relaunch your product.
It worked perfectly. We couldn't find it to try that, with the new location in Windows 7.
Thanks so much.
