Installation & Licensing
Member
elroykhlo
Message 1 of 6 (463 Views)
AutoCAD Licensing Manager on NIC Teaming
463 Views, 5 Replies
03-02-2013 09:35 AM
Dear All,
  I would like to ask if licensing manager can be installed on a server with nic teaming or not. LMtools reported mac address "fffffff" on a nic teaming and the license file is prompted invalid. However, when i register the license with te teaming nic MAC address. the license is valid and the MAC address is stilled "ffffffff".
**the license register prompted that it reaches limit of the product registration. What can I do?
Elroy
DarrenP
Message 2 of 6 (446 Views)
Re: AutoCAD Licensing Manager on NIC Teaming
03-02-2013 04:50 PM in reply to: elroykhlo
disable the teamed nic cards and get an actual mac address
TravisNave
Message 3 of 6 (392 Views)
03-04-2013 09:16 AM in reply to: elroykhlo
I agree with Darren.
If you cannot unteam them due to some odd policy, then use the GETMAC command at a command prompt to obtain your MAC address.  So long as one of the MACs is valid and active, you should be able to get a working license file.  You might also be able to set the MAC address on the teamed adapter manually if needed.
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
Member
elroykhlo
Message 4 of 6 (373 Views)
03-04-2013 08:11 PM in reply to: elroykhlo
I have tried to add both adapter mac address to the license. However, it cannot provide the service..
Member
elroykhlo
Message 5 of 6 (372 Views)
03-04-2013 08:12 PM in reply to: TravisNave
And also, I have another issue is that when I register the license server and MAC address with the license key. It prompted that the limit has been reach. Is that anything I can do to erase the worng mac address registered before?
TravisNave
Message 6 of 6 (287 Views)
03-08-2013 06:37 AM in reply to: elroykhlo
Yes, contact Autodesk Activations and they will get you the LIC file that you need.
You can use the online method to activate your license here:
http://usa.autodesk.com/adsk/servlet/pc/item?id=18424632&siteID=123112
Or you can can call Autodesk Product Registration and Authorization:
http://en.autodesk.ca/adsk/servlet/index?siteID=9719649&id=9830778
1-800-551-1490 > Option 1 (English) > Option 2 > (Network)
Asia / Pacific: 65.6735.5688
Europe / Middle East / Asia: 41.32.723.9595
You will need to provide your serial number and ethernet ID of the new license server.
