• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    New Member
    AutoCAD License Transfer Problem
    335 Views, 2 Replies
    11-14-2012 04:30 AM
    I am trying to install AutoCAD 2013 onto my new laptop, and whenever I try to activate, it says the license (an educational) is already in use on another computer. This was the case - I couldn't install on my old laptop, and I had to use a work machine. When I got my new laptop last week, the user of the other computer, who had generously lent me use of it until mine arrived, uninstalled without transferring the license. Now, I can't use the license, and Autodesk won't get back to me on the subject (communications stopped on Thursday).
    AutoCAD 2013 Windows 64-bit, running on a Windows 7 machine, in case that matters. All hardware specs exceed minimum requirements.
    Please use plain text.
    TravisNave
    Re: AutoCAD License Transfer Problem
    11-14-2012 07:45 AM in reply to: spencerbogucki
    You might see if the user of the original laptop can run the LTU for you and transfer the license.  Otherwise, Autodesk will have to activate it for you.  Good luck!
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    New Member
    11-14-2012 05:34 PM in reply to: spencerbogucki
    I borrowed the coworker's laptop, reinstalled 2013, and ran the License Transfer Utility successfully. I can now use AutoCAD 2013 Student Edition on my personal laptop, as it should be.
    I declare this problem resolved.
