• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    New Member
    superdave123456
    AutoCAD LT won't run
    299 Views, 3 Replies
    07-07-2011 06:40 AM
    I installed AutoCAD LT on an XP machine running SP3 with 4 gigs of ram, a 250 gig hard drive, and an Intel i-5 3.20 GHz cpu.  It is a work computer and I am getting an error stating either there is a problem with the install or that there isn't sufficient rights to run the program.  I have attempted to run the program with the highest administration level, with no success.  Alternately when I install it on my Windows 7 work computer using myself as the administrator, it runs no problem.  Any suggestions would be greatly appreciated.
    Please use plain text.
    Product Support
    Re: AutoCAD LT won't run
    07-13-2011 01:12 PM in reply to: superdave123456
    If the error is:
    Unable to run AutoCAD.  This may be due to one of the following reasons:
    1)  This version of AutoCAD was not installed properly.  In this case, you may wish to reinstall AutoCAD.
    2) You do not have sufficient rights to run AutoCAD.
    The only solution is to reformat the computer with a clean Windows XP.  Also, with 4 GB of RAM, I would get a x64 operating system because XP can only use 3 GB with the 'switch'.
    http://usa.autodesk.com/getdoc/id=TS1060353
    David Lau
    Product Support | Up and Ready Blog | If my reply was helpful, please Kudo or Accept as Solution. :smileywink:
    My 5 Top Issues in the Discussion Groups
    1402 Error [Uninstall] | Faro doesn't install | adlmPITSetProductInformation Errors | Empty Tool bar in AutoCAD Mac | Win 7 Registry Limit
    New Member
    11-23-2012 08:41 AM in reply to: superdave123456
    It happens to me on Windows 7
    Only the admin that installed may run the program
    Even other admins get the error they are not admins
    Should I reformat ?
    I hope you can find another solution for me
    Product Support
    11-23-2012 09:41 AM in reply to: superdave123456
    This workflow should work:
    • Elevate the user to Admin.
    • Run AutoCAD in that acccount and confirm that it works.
    • Remove Admin privileges to the end user.
    If you have tried this already, then some files in the registry are not being written or edited.
    You may need to extrapolate the registy values and locations from this solution:
    http://usa.autodesk.com/getdoc/id=TS19170578
    David Lau
