I cannot get the Digital River site to complete my renewal. Need help, Autodesk cannot help.
Solved by philip.s. Go to Solution.
My apologies for the inconvenience Joe.
This is a somewhat common error and is typically caused by the extra 4 postal code numbers on the Step 1: Shopping Cart/Billing page. In this case, you simply need to remove the -4928 so that the Zip/Postal code contains the standard 5 digits.
Please let me know if that does the trick / accept as a solution if this fully resolves the issue, or reply with additional specifics if the problem persists.
