I intend to buy AutoCAD LT 2014 for my business and thought I'd check out the free trial to make sure it has everything I need. I have installed it on my computer and when I open it, it crashes and shuts down as soon as the first working screen appears.
Please help!!
Estelle
You're going to hate my idea...
Autodesk recommended uninstall/reinstall procedures are as follows
Uninstall: http://usa.autodesk.com/getdoc/id=TS45252
Ensure the user installing/uninstalling and using the product have enough rights to do so (install and reinstall as local administrator):
Unable to run AutoCAD® as a restricted user http://usa.autodesk.com/getdoc/id=TS1055299
More complete .NET fix if you did not go through this procedure:
http://forums.autodesk.com/t5/Installation-Licensing/NET-Framework-Cleanup-Tool-for-Unhandled-Except...
Restart Windows.
Try the install again.
My autocad LT 2014 online trial was running but crashed. after I restarted my computer and tried re-opening LT 14 trial, I get a dialogue box that is requesting a password. WindowsServer2008R2 datacenter. I was never given a password when installing the online trial. I'm also testing out versions before purchasing because I cannot afford the revit package I was used to at my last company. How do I get back into my 30 day trial?
