I understand that AutoCAD LT 2012 can be installed on a desktop and laptop if they are for the sole use of a individual user and nobody else.
The documentation located so far refers to installing on both machines and then exporting/importing the licenses backward and forwards between the computers as required with the occassional issue.
I would like to avoid this scenario and assume that if nobody else uses the computers it would be acceptable to install on both machines? If so, what would I need to do to avoid the inconvenience of exporting/importing licenses each time?
I hope to hear from you very soon
Activate your desktop. Activate your laptop. Done.
The EULA explains this in detail. You can do so without issue. Good luck!
