Installation & Licensing
Active Member
Message 1 of 10 (908 Views)
Accepted Solution
AutoCAD LT 2012 - installation error
908 Views, 9 Replies
12-06-2012 05:54 AM
Hello!
I get the attached error when installing autocad LT 2012. (just after running setup.exe)
(in norwegain it says: "The system cannot open the device or file specified..")
I'm using the original DVD and I have tried this on several PC's but get the same error.
The strange thing is that I installed from this dvd a year ago, and it worked..
any help is appreciated!
Product Support
aaronhai
Message 2 of 10 (869 Views)
Re: AutoCAD LT 2012 - installation error
12-07-2012 12:52 AM in reply to: eirikh
Hi eirikh,
Welcome to Autodesk Discussion Groups.
Please see if it is due to the issues described in this Autodesk blogpost and Forum.
Thank you.
Aaron Hai
Active Member
Message 3 of 10 (778 Views)
01-14-2013 05:44 AM in reply to: aaronhai
sorry for late reply to this. No, it doesnt work. Drive is not encrypted. Different media tried to no use. Will check if ordering USB media helps.
Active Member
Message 4 of 10 (746 Views)
01-16-2013 04:12 AM in reply to: eirikh
Download media tried. I get the same error!
Customer Service
celine.manca
Message 5 of 10 (736 Views)
01-16-2013 04:52 AM in reply to: eirikh
Hi Erik,
Did you already order the media of your product or do you need some help ?
Celine Manca
Active Member
Message 6 of 10 (733 Views)
01-16-2013 04:57 AM in reply to: celine.manca
Ordered new media (DVD) and downloaded media as well. Both give me the error described above.
(tried it on several domain Windows7 x64 pc's)
Product Support
Message 7 of 10 (720 Views)
01-16-2013 06:37 AM in reply to: eirikh
Please try to install the software in diagnostics mode as described here.
http://usa.autodesk.com/getdoc/id=TS75218
If it fails, Please try to run this utility from Microsoft to clean the windows installer.
http://support.microsoft.com/kb/2438651
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
For more tips & tricks: http://upandready.typepad.com
Hashim Mundol
Autodesk Product Support
Autodesk, Inc.
Active Member
Message 8 of 10 (698 Views)
01-17-2013 06:10 AM in reply to: hashim.mundol
Running this in safe mode was no use, as it needs the windows installer service, which isnt avaliable in safe mode..or so it says.
This one found no errors..and therefore did nothing.
Active Member
Message 9 of 10 (672 Views)
01-22-2013 05:43 AM in reply to: eirikh
I found the solution - Ran the install in safe mode as admin, and ran this tool to get the Windows Installer service going: http://www.technibble.com/safemsi-exe-start-windows-installer-service-in-safe-mode/
Active Member
Message 10 of 10 (302 Views)
09-02-2013 08:02 AM in reply to: eirikh
amigos un gran favor miren cuando instalo autocad Civil 3D 2013, justo casi al final de la instalacion despues deinstalar languaje pack  me sale un error que dice "placeholder" que pueddo ahcer porq me sale este error y como puedo subsanarlo estaria muy agradecido si me responden lo mas nates posible gracias
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Connect with Us
Twitter
Pinterest
Blog
Youtube
