• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    Active Member
    Accepted Solution
    AutoCAD LT 2012 - installation error
    522 Views, 8 Replies
    12-06-2012 05:54 AM
    Hello!
    I get the attached error when installing autocad LT 2012. (just after running setup.exe)
    (in norwegain it says: "The system cannot open the device or file specified..")
    I'm using the original DVD and I have tried this on several PC's but get the same error.
    The strange thing is that I installed from this dvd a year ago, and it worked..
    any help is appreciated!
    Please use plain text.
    Product Support
    aaronhai
    Re: AutoCAD LT 2012 - installation error
    12-07-2012 12:52 AM in reply to: eirikh
    Hi eirikh,
    Welcome to Autodesk Discussion Groups.
    Please see if it is due to the issues described in this Autodesk blogpost and Forum.
    Thank you.
    Aaron Hai
    AutodeskCare | Product Support
    TW | PI | YT | BLOG
    If my reply was helpful, please Kudo or Accept as Solution. :smileyhappy:
    Active Member
    01-14-2013 05:44 AM in reply to: aaronhai
    sorry for late reply to this. No, it doesnt work. Drive is not encrypted. Different media tried to no use. Will check if ordering USB media helps.
    Active Member
    01-16-2013 04:12 AM in reply to: eirikh
    Download media tried. I get the same error!
    Customer Service
    celine.manca
    01-16-2013 04:52 AM in reply to: eirikh
    Hi Erik,
    Did you already order the media of your product or do you need some help ?
    Celine Manca
    AutodeskHelp | Customer Care Representative
    TW | PI | YT | BLOG
    Active Member
    01-16-2013 04:57 AM in reply to: celine.manca
    Ordered new media (DVD) and downloaded media as well. Both give me the error described above.
    (tried it on several domain Windows7 x64 pc's)
    Product Support
    01-16-2013 06:37 AM in reply to: eirikh
    Please try to install the software in diagnostics mode as described here.
    http://usa.autodesk.com/getdoc/id=TS75218
    If it fails, Please try to run this utility from Microsoft to clean the windows installer.
    http://support.microsoft.com/kb/2438651
    If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
    For more tips & tricks: http://upandready.typepad.com
    Hashim Mundol
    Autodesk Product Support
    Autodesk, Inc.
    Active Member
    01-17-2013 06:10 AM in reply to: hashim.mundol
    Running this in safe mode was no use, as it needs the windows installer service, which isnt avaliable in safe mode..or so it says.
    This one found no errors..and therefore did nothing.
    Active Member
    01-22-2013 05:43 AM in reply to: eirikh
    I found the solution - Ran the install in safe mode as admin, and ran this tool to get the Windows Installer service going: http://www.technibble.com/safemsi-exe-start-windows-installer-service-in-safe-mode/
