Installation & Licensing
Active Member
ahoarima
Message 1 of 7 (596 Views)
Accepted Solution
AutoCAD LT 2012 64-bit hangs at first start
596 Views, 6 Replies
09-08-2011 10:39 PM
We have Windows 7 64-bit and for some reason some of our AutoCAD LT 2012 hangs to loading state when we try to start program at first time. Installation goes successfully and there isn't any errors. What is the problem?
New Member
RockinToro
Message 2 of 7 (592 Views)
Re: AutoCAD LT 2012 64-bit hangs at first start
09-09-2011 02:57 AM in reply to: ahoarima
I have the same problem!
I want to start first time, to bring the licence key. Then there is the new window an only white! nothing else!
I de-installed and installed again. always the same fault.
what can i do?
*Expert Elite*
TravisNave
Message 3 of 7 (578 Views)
09-09-2011 07:49 AM in reply to: RockinToro
For more information on this known Autodesk Support Knowledge Base article, please follow this link:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=6404339&linkID=9240617
Additional discussion about this issue can be found here:
http://forums.autodesk.com/t5/Installation-Licensing/Blank-Activation-Screen/td-p/2862508
For more detailed information about the CascadeInfo.cas file, please refer to the Autodesk Support Knowledge Base article found here:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?linkID=9240617&id=13894457&siteID=123112
For non-license related instances where your Autodesk product starts and hangs, please review this Autodesk KB on the InfoCenter:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15228698&linkID=9240617
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
Active Member
ahoarima
Message 4 of 7 (562 Views)
09-14-2011 04:37 AM in reply to: TravisNave
I installed also service pack but there isn't any help. Also i tried uninstall F-secure antivirus program but no luck. I could't find that wscommcntr2.exe process from task manager. What next?
Active Member
ahoarima
Message 5 of 7 (543 Views)
09-19-2011 05:12 AM in reply to: ahoarima
I disabled Infocenter from register and now it is going forward but hangs again.
Active Member
ahoarima
Message 6 of 7 (526 Views)
09-20-2011 11:54 PM in reply to: ahoarima
Problem solved! Reason for freezing was M-Files client witch was old version.
New Member
Message 7 of 7 (185 Views)
03-25-2013 11:28 AM in reply to: ahoarima
So I have to be a programer to load AutoCad?
I'll keep trying but I must say this has been a horrible experience.
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Connect with Us
Twitter
Pinterest
Blog
Youtube
