Installation & Licensing
AutoCAD LT 2011 activation failed
3 REPLIES 3
453 Views, 3 Replies
I have my License version Autocad2011 LT with serial no and Product key. After formatted my PC i installed acad but its not getting activated.i followed all the steps properly.
Anybody can give solution to my problem ??
Chandran
3 REPLIES 3
joane.bonghanoy
Hi starchandran,
What is the error message encountered? Do send a screenshot (please remove any Serial Number information on the screenshot) so I can further check on it
You can also click here for more details and some troubleshooting steps on Product Activation.
Joane Bonghanoy
in reply to: joane.bonghanoy
HI,
PLEASE FIND THE ATTACHED SCREEN SHOT OF AUTOCAD LT 2011 PROCESSING ERROR.
REGARDS,
CHANDRAN.M
byron.morales
Hello Chandran,
Please do the following:
1. Rename the following file by adding a .bak extension at the end of the filename.
   Windows XP    C:\Documents and Settings\All Users\Application Data\FLEXnet\adskflex_*_tsf.data
   Vista/Windows 7
   C:\ProgramData\FLEXnet\adskflex_*_tsf.data
This file contains all activations for all 2010 and newer Autodesk products.  You will need to re-register all your products if this file is renamed/deleted.
2. Restart AutoCAD and it will automatically re-register via Register Today and it will start up as expected.   A new adskflex_*_tsf.data file will be created when you re-register your product.
Let me know if the above steps helps to resolve the activation issue.
Byron M.
Administrator Productivity
