I have my License version Autocad2011 LT with serial no and Product key. After formatted my PC i installed acad but its not getting activated.i followed all the steps properly.
Anybody can give solution to my problem ??
Chandran
Hi starchandran,
What is the error message encountered? Do send a screenshot (please remove any Serial Number information on the screenshot) so I can further check on it
You can also click here for more details and some troubleshooting steps on Product Activation.
HI,
PLEASE FIND THE ATTACHED SCREEN SHOT OF AUTOCAD LT 2011 PROCESSING ERROR.
REGARDS,
CHANDRAN.M
Hello Chandran,
Please do the following:
1. Rename the following file by adding a .bak extension at the end of the filename.
Windows XP C:\Documents and Settings\All Users\Application Data\FLEXnet\adskflex_*_tsf.data
Vista/Windows 7
C:\ProgramData\FLEXnet\adskflex_*_tsf.data
This file contains all activations for all 2010 and newer Autodesk products. You will need to re-register all your products if this file is renamed/deleted.
2. Restart AutoCAD and it will automatically re-register via Register Today and it will start up as expected. A new adskflex_*_tsf.data file will be created when you re-register your product.
Let me know if the above steps helps to resolve the activation issue.
