I have been running AutoCAD LT 2009 on an XP (32bit) machine that I would like to retire. I recently purchased a new machine with Windows 7 (64bit). I gather from other posts that a 64 bit version of 2009LT exists, however, when I originally installed LT2009 on the old machine, I downloaded it from autodesk and so do not have the disk (that contains the 64bit version). At the time of install, I saved the exe file for the 32 bit version but that will not install on the new 64bit machines. I currently have no way of utilizing our 2009LT license on the new machine - even to purchase an upgrade.
Is there a way for us to purchase an upgrade to LT 2011 (64 bit) and get the new machine operational or am I stuck having to purchase a full license at 64bit?
Thanks.
Solved by DarrenP. Go to Solution.
all you need is a vaild serial number to upgrade your going to have to talk to a local reseller to upgrade
no one separates the 2 products both the 32 bit and 64 bit program are in the same box
DarrenP
