• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    Active Member
    nd.g
    AutoCAD Failed to Install
    644 Views, 4 Replies
    10-14-2011 09:37 AM
    I'm trying to install AutoCAD 2012 onto my computer (I have Windows Vista Home Premium 64bit) but each time it comes up saying that it failed to install. An error appears about half way through installation and then the number of items installed appears to go down (i.e. whereas it might have said before that 5 out 10 are left to install, it will then say that 6 are left, then 7 etc). I have tried to install the 2011 version, but this also had the same problem. I have copied the installation log below and would appreciate any helpful suggestions.
    ProductSelectionDialog2
    2011/10/14:16:54:23 Nick NICK-PC PageOpen FullProgressDialog
    2011/10/14:16:54:23 Nick NICK-PC Installing DirectX Runtime: C:\Autodesk\AutoCAD_2012_English_Win_64bit\3rdParty\DirectX\DXSETUP.exe /silent
    2011/10/14:16:55:41 Nick NICK-PC Install DirectX Runtime Succeeded
    2011/10/14:16:55:41 Nick NICK-PC Installing FaroSDK: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
    2011/10/14:16:56:09 Nick NICK-PC Install FaroSDK Succeeded
    2011/10/14:16:56:09 Nick NICK-PC Installing Autodesk Material Library 2012: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
    2011/10/14:16:57:01 Nick NICK-PC Install Autodesk Material Library 2012 Succeeded
    2011/10/14:16:57:01 Nick NICK-PC Installing Autodesk Material Library 2012 - Low Resolution: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
    2011/10/14:16:57:50 Nick NICK-PC Install Autodesk Material Library 2012 - Low Resolution Succeeded
    2011/10/14:16:57:54 Nick NICK-PC Installing AutoCAD® 2012: TRANSFORMS="C:\Autodesk\AutoCAD_2012_English_Win_64bit\x64\en-us\acad\acad.mst;C:\Users\Nick\AppData\Local\Temp\_AI6FD2.tmp\x64\acad\acad-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2012 - English\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
    2011/10/14:17:05:25 Nick NICK-PC Install AutoCAD® 2012 Failed Installation aborted, Result=1603
    2011/10/14:17:06:24 Nick NICK-PC Rollback Autodesk Material Library 2012 - Low Resolution Succeeded
    2011/10/14:17:08:06 Nick NICK-PC Rollback Autodesk Material Library 2012 Succeeded
    2011/10/14:17:08:12 Nick NICK-PC Rollback FaroSDK Succeeded
    2011/10/14:17:08:12 Nick NICK-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
    Please use plain text.
    *Expert Elite*
    TravisNave
    Re: AutoCAD Failed to Install
    10-14-2011 10:02 AM in reply to: nd.g
    What is the error that you get half-way thru the installation?  Also, there should be a larger installation log file located in your %TEMP% folder.
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    Active Member
    nd.g
    10-14-2011 01:55 PM in reply to: TravisNave
    It says Internal Error 2738
    I've found a folder called TEMP, I'm can't find anything that might be the installation log though
    Sorry for posting twice, i wasn't sure which was the right forum
    *Expert Elite*
    TravisNave
    10-14-2011 02:49 PM in reply to: nd.g
    No problem.  Usually the discussion_admin will move it to the right forum.
    To get to your %TEMP% folder, just go to Start > Run and type %TEMP% or just type %TEMP% in the address bar of your Windows Explorer.
    David Lau wanted you to try this:
    http://upandready.typepad.com/up_and_ready/2011/09/autocad-2012-mainenginethread-is-returning-1603-....
    Travis Nave
    Active Member
    nd.g
    10-14-2011 06:28 PM in reply to: nd.g
    I tried that link and installed the recommended hotfix, but I'm still getting Internal Error 2738 and the same problems as before.
    Also, I can't find a %TEMP% file anywhere. The closest I have is called TEMP but that doesn't look like it has anything from today in.
