I have always used my companies AutoCAD Electrical 2013 at work but I was told that I could install it at home also as a convenience as long as the two aren't running at the same time. I have a new computer at home now and installed the program but when it tried to activate it I got a serial number invalid error.
I tried the help chat but it is always busy so I am posting here. Are there other steps or should I just delete AutoCAD Electrical 2013 from my home computer?
Solved by jessica.t. Go to Solution.
@PaulRogers wrote:I have always used my companies AutoCAD Electrical 2013 at work but I was told that I could install it at home also as a convenience as long as the two aren't running at the same time. I have a new computer at home now and installed the program but when it tried to activate it I got a serial number invalid error.
You should talk to your reseller about the proper method for doing this. They should help you avoid any unecessary conversations with the ADSK compliance people.
Compliance? Everything I have seen on here says you can have a second install on a home computer as long as both aren't running at the same time.
Is that legal or not?
If not I will gladly remove it from my home computer, if it is ok why should I have to worry about compliance.
This was the only recource I had available to me for help and I am greeted by someone with the name "Just Shut Up" by Autodesk.
Amazing.
Hi @PaulRogers,
Yes, you can have a single seat standalone license installed on a maximum of two machines. Typically you receive the invalid serial number error when a license has been upgraded or returned. Please contact the Activation and Registration team to have them confirm your license:
1. Visit http://knowledge.autodesk.com/contactus
2. Select “Activation & Registration” or “License Management”
3. Select appropriate subtopics from the pull-down menus
4. Select “I Still Need Help” if you need personal assistance
If you have any further questions or concerns please reply to this post. Thank you!
@PaulRogers wrote:Compliance? Everything I have seen on here says you can have a second install on a home computer as long as both aren't running at the same time.
Amazing.
The amazing part is that you think that this forum is made up of only ADSK people.
